I have used one very similar for a while now. OK for basic diagnostics and helps to eliminate the obvious (battery, free train, coil etc).  Instructions for use were not very good but it is simple enough to use.  There are better and more expensive ones for the professionals, but this type is ok for the rest of us.
  • 4 months later...
Hi all, I am a new member and was looking for some advise. I have a fully kitted out workshop at work with the best equipment up to accreditation level from most brands but am looking to build a small workbench at home on a budget. The next thing on my list is a machine that will test the consumption of a Quartz movement. I have the all singing all dancing witchi one at work but was looking for a cheaper more basic alternative for at home. The cheapest I have found is the horotec Flashtest, has anyone any experience with this tester or is there a cheaper alternative. I only need to test the the consumption of the movement on 1.5v Watch's, I don't need it to do anything else.
Your help and advise would be greatly appreciated
thanks
If you only need to test consumption (drain) all you have to is to get a broken quartz movement, remove all components, solder two wires to it to + and - pads, terminate these with a crocodile clip. you can now put a battery in it and measure with any common tester.
Otherwise there are cheap testers like this
http://www.aliexpress.com/item/Free-Shipping-2013-Latest-Quartz-Watch-Impulse-Button-Battery-Checker-Battery-Tester-Watch-Tools/1581946931.html
Thanks for the reply, the tester you have linked to is not quite what I am wanting. I want to be able to remove the battery from say a tag Watch with a eta 955 112 movement and then put a prong on the + and a prong on the - which will then give a reading in μA. For example this eta calibre should read below 1.5μA for a new battery to last 2 years, if the reading is higher than this it means the watch needs a service because it's consuming too much from the battery and the battery won't last the 2 year period it should. The tests can be quite a low reading for some calibres so would think the devise used will have to have a digital display to be accurate. Some ladies Watch's should be .5 and the Rolex oyster Quartz can be as high as around 9μA going from memory so it needs to be quite accurate.
This is the cheapest version I have found so far that will do it. The test I want to do is test 6 in the instructions in the link below.
http://www.horotec.ch/flashtest/ModeEmploiANGLAIS.pdf
You are correct, I didn't realized that the device above doesn't do what you require. I could not find a cheap dedicated instrument so all you have to do is to use an external battery and a good multimeter. This one has a 20 uA setting which should work
http://www.aliexpress.com/item/High-Accuracy-General-Manual-Range-Digital-Multimeters-UNI-T-UT39A-Amp-Ohm-Volt-Meter-Digital-LCD/1000001391486.html
  • 6 months later...
Without knowing the exact name and type of the component, it's simply an electro-magnetic sensor. However in my opinion is that the watch runs it's pointless to see that it pulses - evidently it does. What you may want to know is the timing and shape of the pulse, for which you need a much, more sophisticated machine.
There is a benefit to such a detector as it is a quick way to determine whether a non-running watch is suffering an electrical/electronic fault or a mechanical blockage since a mechanically seized movement will still pulse without the hands moving.
A simple diagnostic routine for a non-running quartz watch might be;
Pulse detected - mechanics need freeing/servicing
No pulse - check continuity of coil
If coil is open circuit then replace coil
If coil is good but there is still no pulse then electronic module is faulty
At this level of simplicity a tester can be picked up off eBay for as little as £15 or so and could save a lot of time if you do a lot of quartz movements. Something more sophisticated would certainly be of benefit if you going to get into repairing the electronic modules but then the cost does go up considerably.
  • 8 months later...
I was reading up about this tester and nobody has passed any coments about the `Horotec Flashtest` tester, that is why I have mentioned it; specifically. Maybe someone who hasn`t seen my prevoius article will see this one.
27 minutes ago, Ray said:
I have one and used it for the BHI Quartz servicing exam. A great little device that does almost everything you need at the fraction of the price of a Witschi
Can't compare this to Witschi, which has a full screen oscilloscope showing the shape of the pulse (important on the latest generation, low drawn movt.s), memory, and heaven known how many things more. A top laboratory would get that, an hobbyist or a budget professional the $30 boxes mentioned in the thread above.
Edited by jdm
I think unless you're working on quartz a lot, it's hard to justify the cost. Please don't do this with your Omega's but if you have a cheap quartz movement and suspect the train is stuck. You can use a cheap Chinese demagetiser $15. Place the movement and press the button. The hands will spin and the second hand is likely to spin off into orbit. See pics. No damage was done to the movement and it still keeps time. And no the rotor was not demagetised. No I'm not accepting liability for this BAD practice. Note how fast the second hand is rotating! [emoji16]cdb4598a1d563882110b7f4e23a68d8a.jpgd12c81a6376d778882a6564b88c44fc2.jpg86de6d3e819b454d370939304e3e8db7.jpg
The Witschi is a serious machine with a serious price which is not suitable or justifiable for the hobbyist, the horotec tests voltage consumption, lowest working voltage, coil resistance, battery voltage under load and end of life indicator and the rate. Which is all I'll ever need.
(Test battery consumption). My point is that you can have all that for maybe $80, not $439. But to each one his own.
Edited by jdm
  • 7 months later...
  • Similar Content
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
