Bizarre day date change
Hi everyone and hope everyone is OK. bought this watch in a joblot for a tenner (£10.00) so no complaints. The watch works fine but the date changes an hour forward every 24 hours. So if I cycle through the watch and it changes at 12, the next cycle it will be 1am, the next 2am etc. I also removed the hands, cycled the watch to the precise time of date change and then replaced the hands at the 12 O'clock position but the date started to change at the half past position with the same problem as above. The hands sit fine and are snug. Any ideas on what is going on? Many thanks and kind regards.
Pedro.
Just so I understand clearly first it's an hour off then you reposition the hands it's one half hour off?
As it's the calendar parts shall have to take the hands and dial off and see what's going on.
Then it's hard to go beyond this because which movement is this? But we could guess if the hands are actually tracking it's probably not a Canon opinion the problem perhaps. That takes us back to something to do with the the calendar parts which are under the dial unfortunately. Then we can't even look for a tech sheet if one even exists without a movement identification. But more likely have the watch hasn't been serviced in a long time that needs to be done.
Sounds like an interesting symtom, is it falling exactly 1 hour behind with every daychange or what?
A guess with that day date 70's model it would house an 718 movement.
Hi, yes it is a 718 movement. Never come across this problem before. The watch is keeping great time but every day the date change changes an hour forward so one day will change at say 1am, the next 2am and so forth
Had to take a look how one of these loooked like, just happened to have a ORIS Twin Date lying around.
The day date share the same disk for the day date change which is driven through some gears by the hour wheel.
The hour wheel as you know is driven by the small pinion on the minute wheel, and the minute wheel is driven by the cannon pinion. This configuration should ensure the change of time and date to be synchronised by the time.
So if the day date would be affected by the cannon pinion I would expect the time to be off too (check if the time slipps too). So if the time isn't affected this leaves us to the day and date disks, they either got loose from their gears or the day date jumpers are not correctly aligned.
Edited by HSL
Cheers, the movement you have posted is identical to mine. As I am writing this the watch is still keeping excellent time but will keep an eye on it. Will have a look tomorrow and keep you posted, many thanks for your time, effort and advice, it is much appreciated.
Kind regards
Pedro.
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it.
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
