eterna crowns
Hi
This may just be me? How the hell do you wind up a enterna centemaire watch, the crown is so small or my fingers to big. Its the only watch i have trouble winding up. I   know its automatic but i like to wind them to check keyless work is all fine. Also the auto winder is not working on this one so winding it up would have helped.
Is there a knack to winding them or is there some tool i could use to wind it.
I have just got a second one and its the same problem the crown is fitted and to small to wind.
My wife cannot do it nor any of the grand kids.
any  advice appreciated
cheers
gary
I had one of those too not to long ago, to wind it I had to push my finger forward from underneath instead of trying to rotate the crown. The design is a bit qirky. My fingers are like on a concert pianist so they also was useless in winding this one ?
Edited by HSL
Hi Gary  Nothing specific on the 1406U but have the 1407 1405, and according to Ranfft its close in design to the Zenith 135 so I popped that one on too.       There are manual watch winders out there they are like a small spring loaded clamp  I have attached images. They come in different sizes to fit the crowns.      cheers
1176_Eterna 1407.pdf Eterna 1405.pdf 2656_Zenith 135.pdf
I second watchweasol with the manual winder. I have one size that so far has fit 95% of the watches I work on, so I don't think you'll need a whole set. Saves the fingers, and winding some of the smaller size vintage crowns (and women's) with my tubby fingers was near impossible.
The challenge with these Eterna Centenaire  Is as I earlier said the design of how the watch case is designed. On the top the crown is sunk in and has a chamfer on the top to (Eterna called this concealed crown) . Underneath there is a groove machined. I assume it looks the same on Garys watch.
I wouldn’t recommend using a watch winder tool on this one since it will just slip on the chamfer and it even might scratch the crown.
Watch winding tools only should be used on a watch with well known functionality, if the key-less work is a bit bad due to wear and tear or old dirt the extra leverage the handle gives might break off the winding stem, the threading is the weak link here. So use those with care.
Edited by HSL
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
