Hi everyone!
Terho
New member here! I am a hobbyist interested in working with small and beautiful things, like watches, pocket watches, jewelry and precision mechanics; typically using, metal, bullion, wood, gems and pearls. With watches I have so far been working mainly with old pockets watch repairs and learning techniques and getting more tools.
    • Before putting it back in the case I would fit the hands and use a pin vice on the stem to make sure the hands were in line.
