Eternamatic movement removal?
I have this Eternamatic that I am trying to identify and hopefully clean without damaging it or the Dial. The movement comes out with the case back, and I am assuming that the crown must be removed to access the movement?20210509_143451.thumb.jpg.4a41e0ed6e035c42e301f44029900ecc.jpg
Could be a two part stem. Some just pull apart, some will come apart if the stem is rotated just right.
My first course will be to try to lever the movement out by prying (gently!!!) under the dial on the crown side while simultaneously rotating the crown.
If that doesnt work then try pulling out the crown. However I would wait a few days to see if any others has had experience with this watch/case before trying.
rgds
Anilv
rgds
Anilv
Thanks Anilv, I am not in a hurry but that gives me a couple of options to try, I don't want to damage the dial. After I figure out how to get it apart I will need some pointers on cleaning the dial. It seems that the glue from the gasket has gummed up the edges of the dial. Thanks again for the advice.
I noticed at 3 and 9, on the sub bezel? there are recesses, which seem to be intended for placing a screwdriver to compress the lens, (if the lens is acyrlic ) and perhaps once the lens is out, the movement and dial exit out the front. If the lens is glass, perhaps those recesses are to lever the bezel/sub-bezel? off.  I remember another watch I worked on, where the movement, dial, stem and all exited out the front, only after the crystal was removed. a Vacheron & Constantin-LeCoultre Galaxy, with a mystery dial if I remember correctly.
Or, as mentioned by someone else, it may be a split stem, or possibly a split stem, and out the front as well. Like the Omega Seamaster Cosmic. Really hard to say without a side view pic.
I believe in any case, that at some point, those recesses at 3 and 9 will be useful in some way. All conjecture on my part, no guarantees, only possibilities.
Seems to me that the crystal is out already, as suggested above turn the crown slowly to align the stem joint while lifting up gently.
Thanks, the top half of the case has set screws that allow you to remove it along with the crystal, now as you see it the dial is exposed and I need to pull the crown and stem to remove the movement. I will try and rotate the crown while prying gently and see if that works. I appreciate your help
On 5/10/2021 at 4:22 PM, OneBadWolf said:
I noticed at 3 and 9, on the sub bezel? there are recesses, .......... that at some point, those recesses at 3 and 9 will be useful in some way.
Hi wolf,
My guess is that these recesses are the edges of a round movement peeking past the dial.
Anilv
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
