Repairing F300 Omega`s
I'm sure periodically someone asks about repairing the Repairing F300 Omega and such like tuning fork watches, can anyone recommend anyone.
I know that there expensive, I've got to wonder if it worth having it done.
In the meantime I've stripped mine down in the hope that it would be possible to get it going again without taking the coils and assembly apart.
Thanks all.
if you're wondering about whether it's worth getting it done the answers no. if you have sentimental feelings for the watch then the answer might be yes.
then doing a partial disassembly in the hopes that you can fix it only works if? Like for instance when was the last time the watch was serviced and what's the problem? Like it hasn't been serviced in a long time that's needed that means it has to come apart. This isn't really a watch to be working on unless you're familiar with tuning fork watches although it does have some nice features that makes it easier than some other tuning fork watches. But getting components is extremely difficult and they're usually really pricey. Then there is the other problem with the electrical stuff you need test equipment for that.
or there is a link for someone who works on them just one minor little problem if you look at the contact page he's on vacation? I know he still responds to the emails but he's taking four months off.
https://electric-watches.co.uk/service-and-repair/
https://electric-watches.co.uk/contact-me/
Omega parts crop up every now and again on ebay but they're overpriced and you can't be certain if they're new old stock or not.
There is a seller 'esa-9162-9164' who every now and then sells complete, and working, modules. They're known as mosaba modules. The component parts are identical to the Omega and they're already set up for modern 1.5V batteries.
To keep the originality of the Omega you would need to swap the plates and bridges around - Omega are copper, the ESA (or any other branded watch) are chrome. The module will need a service anyway so no additional work.
The only tricky part of these watches are the driving pawls which you'll need a microscope to set/adjust correctly. The service manuals are available online.
Make sure you are careful of ESD too, you could blow the transistors.
If you can work on mechanical watches then you have nothing to fear.
Make sure you are careful of ESD too, you could blow the transistor.
Thanks all for your input and the information.
I've been reading all I can about them, including the manuals, the index wheel for me is the most important part, and trying not to damage it, I have cleaned it by following other people's ideas, ultrasonic cleaning it without touching the wheel.
As for the driving pawls, I'm not touching them or the coils.
As for will it go afterwards, it is in the hands of the gods, the movement hasn't been touched in forever, really dirty and gummed up.
The coil did make a noise when I first got it, but that doesn't mean it was working correctly, at the moment this is an experiment to see if I can at least get it to do anything more than it was doing.
I've got tomorrow on my own, piece and quiet, so fingers crossed.
To clean the index wheel and replace it would mean having to set the pawls in the correct position back on the wheel whether you'd have to adjust them or not. Although tiny, they are quite durable.
The fact that it is humming is a really good sign, at least the transistor and coils are good.
Good luck with the rest of the watch.
Well, I found the whole thing very interesting, I ended up stripping all the coils and assembly, I'm amazed how basic the design is.
It's basically one pawl attached to the tuning fork and a static one attached to the upper plate.
I thought I had a microscope, but when I went to use it the computer said it doesn't work with windows 10, dam and blast.
Anyway after spending the afternoon with 2 eye glasses strapped to my head, I've decided that the index wheel is the problem,  it does still buzz, but the wheel does not carry on going.
I have enjoyed doing it, its been an education.
occasionally the wheels show up on eBay I think the last time I saw one it was little over $100.
The little confused by the wording so does the wheel move at all? Or does it run and stop what exactly does it do?
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
