Late Introduction
Hello everyone, first of all my apologies for creating a post before introducing myself. My name is Matt and I am brand new to watch repair. I always had a passion for watches and by now I have a nice collection. Recently I have taken Mark's online course to take it to the next level as a hobbyist.
