3d printed spring winder
I enjoy making tools and over the past couple weeks, I’d keep in the back of my mind to print a spring winder.
Heres the first version that wound a spring 10CA2D31-C109-4120-B31C-66E109AD5554.thumb.jpeg.3df48b3a1c6e794a4a67489f51eec3b0.jpeg
at first, I tried to print the nib that catches the spring head, but it didn’t work. I made another plastic connector with a .050 hole to fit brass rod I could file.
everything fit so tight with sanding, it didn’t need much glue -if any. The nib can be rotated 180 to wind in both hands.
It winds the mainspring into a customizable cassette . I wound this spring the wrong direction so I have to rotate the nib the other direction and cut a hole for the spring to track.
42252DDC-3CF3-4F7B-ADCB-755468E857FC.thumb.jpeg.c6c043643946e57f56e1b3405a79e674.jpegI tried to be lazy and cut a trough in with a razor saw(the photo above was before I cut the trough). I couldn’t even get the spring to fit without kinking it. I guess it really is that delicate. I’ll draw up a new cassette tomorrow and print it. It was only eleven minutes to make:/
i really hope I have diagnosed this watch correctly and this fix will make it reliable. This is the tenth piece I’ve worked on that I haven’t fully figured out what’s wrong with it. A success would be fantastic!?
I have been 3D printing for about five years.  Made lots of cool tools and repair parts for things around the house. It is always a challenge when I go small, however--just not enough resolution.
Looks like you made this work.  I cannot see how you push out the mainspring into the barrel.
I have taken the well-known clock winder plans and drawn them in my 3D tool.  Have not printed yet.  Will use metal parts for all critical, high-stress parts--just 3D print the frame elements.
Im happy to hear others use printing to make functional objects!
I used to have a resin printer. It was good when it worked but it was just too much maintenance so i sold it.
I changed the cassette to the model on the left so I can wind it either direction without hurting the mainspring.
To get the spring out, you treat it like the mainsprings you buy-place it over the barrel and push it out with tweezers through the slit.
I hope you try your winder and let me know how it turns out!
Thats a good question.  What ive had to consistently do is to pay attention to the hook through the trough.  It likes to wedge open so i pinch it with tweezers and push it through. Im getting the hang of it now.
Id imagine something similar with an automatic mainspring and Id probable make the trough a little more open to accommodate or go back to the one winding direction
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
