3d printed spring winder
I enjoy making tools and over the past couple weeks, I’d keep in the back of my mind to print a spring winder.
Heres the first version that wound a spring 10CA2D31-C109-4120-B31C-66E109AD5554.thumb.jpeg.3df48b3a1c6e794a4a67489f51eec3b0.jpeg
at first, I tried to print the nib that catches the spring head, but it didn’t work. I made another plastic connector with a .050 hole to fit brass rod I could file.
everything fit so tight with sanding, it didn’t need much glue -if any. The nib can be rotated 180 to wind in both hands.
It winds the mainspring into a customizable cassette . I wound this spring the wrong direction so I have to rotate the nib the other direction and cut a hole for the spring to track.
42252DDC-3CF3-4F7B-ADCB-755468E857FC.thumb.jpeg.c6c043643946e57f56e1b3405a79e674.jpegI tried to be lazy and cut a trough in with a razor saw(the photo above was before I cut the trough). I couldn’t even get the spring to fit without kinking it. I guess it really is that delicate. I’ll draw up a new cassette tomorrow and print it. It was only eleven minutes to make:/
i really hope I have diagnosed this watch correctly and this fix will make it reliable. This is the tenth piece I’ve worked on that I haven’t fully figured out what’s wrong with it. A success would be fantastic!?
I have been 3D printing for about five years.  Made lots of cool tools and repair parts for things around the house. It is always a challenge when I go small, however--just not enough resolution.
Looks like you made this work.  I cannot see how you push out the mainspring into the barrel.
I have taken the well-known clock winder plans and drawn them in my 3D tool.  Have not printed yet.  Will use metal parts for all critical, high-stress parts--just 3D print the frame elements.
Im happy to hear others use printing to make functional objects!
I used to have a resin printer. It was good when it worked but it was just too much maintenance so i sold it.
I changed the cassette to the model on the left so I can wind it either direction without hurting the mainspring.
To get the spring out, you treat it like the mainsprings you buy-place it over the barrel and push it out with tweezers through the slit.
I hope you try your winder and let me know how it turns out!
Thats a good question.  What ive had to consistently do is to pay attention to the hook through the trough.  It likes to wedge open so i pinch it with tweezers and push it through. Im getting the hang of it now.
Id imagine something similar with an automatic mainspring and Id probable make the trough a little more open to accommodate or go back to the one winding direction
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
