Has anyone used the blower/vacuum wands made by companies like Bergeon? I’m curious about such a setup for ensuring I don’t have any dust when casing up. I see many videos with professional watchmakers and manufactures using these.
Unnecessary gimmick or useful tool? What are your thoughts?
Thanks
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
