Bluing hands
I’m learning how to blue hands and I’m failing miserably.
I’m using a very small brass ashtray, brass shavings and micro torch and I also tried alcohol lamp.
I polish the hands and clean them in methylated spirit (I also tried cleaning them in IPA).
On the odd occasion, they would go through the colour changes as you’d expect, Fairly quickly form yellow to brown to purple to blue. However, 99% of the time I cannot get past the yellow. The brass shavings turn dark, the hand turns yellow, almost brown and it goes no further. From the bottom the hand is touching the shavings is blue (not every time) but not on the top. I keep it just above the flame where it is hottest.
When it works, it happens quickly, it doesn’t take long for the hand to start turning yellow and the other colours but most of the time I can sit there for ages and nothing is happening.
Any ideas what I’m doing wrong?
Successful Blueing hands requires that they are spotlessly clean and absolutely free of grease. Looking at your results that is the issue.using brass shavings is good and has given me the best results.
Blotching is a sign of grease which clockboy has said. I always preferred an old English penny to brass shavings. It takes a few practises to get it right. When blued quench the hand in oil it gives a nice shine. That is how I would blue clock screws, getting them all the same colour takes practise.
They should be clean. I used methylated spirit. When leaving them in for several minutes and moving them around in the spirit didn’t work I used a brand new artist brush to help with the cleaning. When that didn’t work I tried IPA. If some go blue from the bottom they must be clean I presume.
I also have some Horosolv which I’ve not tried yet, that may be another option to try. What do you clean them in before bluing?
I’m thinking I’m not getting enough heat but I’ve watched clock hands being blued in some very thick bluing pan so the small thin ashtray should be OK but I considered making it smaller. Although when it worked it only took a minute or so before they started changing colours all the way to blue so I’m somewhat doubtful that the size matters in this case.
You're showing two different hands there, is the yellow one blue on the bottom? Some stainless steel will get a little yellow but not blue. If the hand is plated then it shouldn't change much or at all. But you say you polished it, so any plating should be gone.
As others have said, cleanliness is the most important thing. I frequently blue hands, I've found that clean benzine works best for me but 99% isopropyl alcohol is good too. A final step I do is lay the hand on clean paper, then give it a stroke across with freshly cut pithwood dipped in clean benzine (or alcohol), then puff with a blower to remove any pith bits. The mechanical cleaning as a last step just before blueing really seems to help. The hand goes in a tray with fine brass filings a few mm deep (I make them by filing brass with a 0 or 2 cut file), over the alcohol lamp, then heat up slowly to get the blue as gradually as possible. Several minutes.
When I make new filings I will heat them in the tray for quite a while before using them to blue, this is to burn off any residue or contaminants. They tend to smoke a bit when new, and that would mess up the blue.
I'm not sure whether the yellow one was blue at the bottom. I spent all day doing it yesterday and that would have been re-polished. I’m quite positive that some hands were yellow on top and blue from the bottom. I cleaned the tweezers too, several times throughout the process.
I do not have any benzine here to try that out. I have methylated spirit, IPA and Horosolv. I’m not so sure about the methylated spirit, it’s purple and it marked my orange rubber mat.
I’ve just polished couple of hands, the middle one has not been polished, that’s straight out of the assortment pack. They are shiny, very shiny. Under the macro lens, depending on the angle and light you can see that they are not perfect, they actually look awful. However, nothing ever looks perfect under the macro lens. As bad as they look, they are very smooth and shiny, I worked my way from 1200 grit to 100000.
This time I heated the shavings to burn off any residue or contaminants. I used Horosolv to clean the hand. I’m still getting the same result, I won’t go past yellow. I don’t know how to capture the colour correctly, in the pictures it doesn’t look right, it’s a very beautiful rich yellow colour, very shiny. It’s not blue from the bottom.
I find that when I post quite a few pictures they are not in the order I uploaded them so avoid any confusion below this post are three pictures before bluing and I’ll make second post how it looks after bluing. In the second post you will see that some brass shavings would start turning almost black.
Before bluing:
I don’t think your flame source is hot enough to get the heat through all those shavings. You said the shavings are turning the colors you want though.
the spectrum of tempering colors are caused by a heat range and your shavings are getting hot enough but are absorbing too much heat. The shavings are there to help even out the temp and make the hands oxidize in a slower more controllable manner. They aren’t even necessary if you have a thick plate but it look  sad if you are using an ashtray.
remove half your shavings and try again.
if it’s not going passed yellow still, remove another half of the remaining shavings and try again and repeat the process until it works.
Yes I polished them but only from the top. The hands I’m using are from an assorted pack of 100 hands that were very cheap, around £3 for the pack so I’m thinking the steel may be cheap too and it could be the steel you mentioned that doesn’t go past yellow?
They turn yellow, look absolutely beautiful and that’s that. No more colour change. It’s almost as if they were going light steel colour again. You may notice it from the second post after bluing, the picture where the hand is shiny, you will see that the edges are richer in colour than the centre. The hand was rich in the colour like that all over but started going pale in the middle.
Quite sure these hands are (nickel-)plated. A bit polishing will not remove the plating. You need pure unplated steel (not stainless steel) or iron for blueing. If cheap or not doesn't matter.
Frank
I thought that too that I may not have enough of heat and I spent all day yesterday trying all sorts, including a very thin layer of shavings but no joy. On the odd occasion some hands would turn blue and it would happen fairly quickly when using the micro torch. That makes me think I have enough of heat. I watched several videos and one guy was bluing clock hands in a rather thick bluing tray. The tray must have been at least a quarter of an inch thick and he had a thick layer of shavings there too, he was using micro torch. I was using quite thick brass spoon last weekend and results were same so I picked up on ebay the small ashtray that’s considerably thinner than the spoon but I get same results.
Frank
Looking at the pack, they all look plated, some are painted, some look like they are made of brass. Perhaps I should pick up a pair of different hands.
I’m 99% sure that I have enough of heat. I almost forgot, last weekend when I couldn’t get past the yellow I tried it on some spare screws. I didn’t do anything with them, no polishing or cleaning. The one on the left was stood upright in the shavings and the other was on its side. I must be achieving the right temperatures with this set up.
I have a link to an interesting video below he's making a pen for bluing. Notice that it's not exactly a lightweight pen it's super heavy and he has a lot of brass and he's basically using the same torch. The only real differences are his is going to hold a heck of a lot a heat it looks like he pre-heat set before putting the hand and. In the above example it doesn't look like enough brass and with the brass pan projecting outward almost like a heat sink it may be waking the heat away?
https://youtu.be/uST7iJgC_gs
then there is the other problem with those hands if those are not steel hands find a magnet make sure and if there plated in other words you cannot blue typically other metals to pretend their steel it has to be steel on the surface.
Then looking at the color spectrum yellow is at the bottom of the scale. Is it a lot a hands to practice just hold onto a hand with something disposable and gently pass it near the flame and see if you can turn up blue don't put it in the flame the probably turn a pretty red color that won't last. So don't worry this could be splotchy just hold the high above the flame is slowly bring it down and see if it will blue it should turn blue at least for a little bit it should go through all the colors before it washes out just make sure you can't blue them.
ah, thanks for responding.
I agree with the above posters. If its cheapo metal that is an unknown source, they may not have the correct metallurgical content to blue.
I am a pro patineur and if the metal isnt silicon bronze, I cant guarantee the color, let alone achieve it by typical means. Spelter, white metal, pot metal, brass, copper, etc., all have different results(if any) under the same circumstances.
The best I can think of in your circumstance is to purchase a blue marker and be finished with it if you dont want to purchase new hands from a known metal.  You can run the permanent marker over them and be done or after the marker dries, seal with a little wax
I don’t want to use a marker, I’d like to do it the proper way.
I tested the hands above a flame, no shavings, no pan. The first time I did it, they turned blue, not pretty but I wasn’t polishing them properly, it was just a test. I polished them again, only quickly to remove the oxidation, cleaned them and tried it again, they were not turning blue, not dark blue, the colours were very pale and after some washed out blue it even started turning green.
Screws, no problem, I’ve repolished the head several times and I was getting nice blue every time.
I suspect the plating, the material and whatever else these hands I bought for practising are not suitable for it.
I also tried the magnet. They get on the magnet but they hesitate. The screws jump on the magnet and so do the pocket watch hands.
I’m looking at Cousins site (I’m in the UK) for some different hands I could practice on. They don’t say what the hands are made of. I’m looking at pocket watch hands because the hands I need to blue are pocket watch hands but I don’t want to practice on them. I’m not concerned about the paint on the hands, it will be good practice taking it off anyway, I’m more concerned about the material they are made of.
What do you think, I’m looking the Horotec, ETA and Miyota. I don’t mind getting all three just don’t want to waste time and money if these are no good for bluing.
https://www.cousinsuk.com/category/hands-pocket-watch
The hands below, that’s after the first test when they were turning blue, the two on the left didn't. There was no point taking a picture after the second try.
The picture of the screw, that was repolished several times, it looks good to me.
It was the steel. I got different test hands and the colour changes work like they should do. The bluing is not perfect on these, I gave them a quick wash in methylated spirit, no ultrasonic, I only wanted to see whether it will finally work.
The ‘magnet test’ works very well. If the hands hesitate to stick on the magnet it is not the right steel for bluing, if they ‘jump’ on the magnet the steel is good.
Having the right steel, I can now carry on and keep testing until I get it perfect.
21 hours ago, nickelsilver said:
It's not perfect but not far off- keep practicing, get all the previous blue off before retrying- it has to be impeccable, then try again!
I'm getting there.
The hand didn’t show in the photo as it looked. There was no purple or light spots. I blame it on mixture of overexposure, lighting and white balance. When I turn the hand 180 degrees it looks completely different. The last two pictures (it's been re-blued, it's not the same as my previous post) will show what a difference different exposure makes. Same hand, different exposures.
I had several goes today and I’m happy except I keep getting blemishes on the spade. I’ll keep trying until it’s perfect.
It’s quite forgiving. I also polished the sides but only as much as I thought was sensible because they are quite rough from the factory and I’d make them too thin. The sides look just fine even though they are not perfectly smooth.
  • Like 5
Bluing is going rather well, it's all about the preparation more than anything.
I should now be able to do the hour and minute hand.
I’m not quite sure how the seconds hand is going to work out. There is a brass tube that goes on the pivot and I don’t know whether it will keep the brass colour after heating. I don’t have a test seconds hand to try it on. Has anyone blued a seconds hand with the brass tube attached?
Been following this one and your path mirrors mine when I wanted to do the  bluing the traditional way. Kinda cool to see and you've gotten some outstanding advice from here.
Second hands-when I've run into them I am careful with the heat so as to keep it to the hand and not the tube. A little discoloration might happen but I usually cured that with a dab from a Sharpie. Good luck! Nice work on the hands BTW
It's very enjoyable to turn old rusty hands into beautiful blued hands.
I'm not quite sure what you mean by keeping the heat to the hand and not the tube. The seconds hand will be on brass shavings with the tube attached.
Sorry about that. I mean I keep the flame away from the tube as much as I can, and concentrate it on either side of it.
    • An incabloc spring? About 10p at the current price 🤣
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
