Hello!!
Am just learning about watch repair these past few months and I just discovered this site with lots of valuable advise.
As of now, I can open case, replace crystals, remove movement from case, replace hands and dial and adjust timing of mechanical watches.  The hardest thing I've done was to swap around the tiny motors in a Swatch irony chronograph quartz watch to get the time function to work again by sacrificing the 1/10 second chronograph capability.
Looking forward to learning from u guys :-)
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
