Bergeon 6016--a very useful tool
LittleWatchShop
This tool has been in the watch bench and until today, I had never used it.
Now I know that it is invaluable.
Today I was fighting with a second hand.  Bending and bending until it cleared the minute hand and did not hit the crystal.  Had to remove the second hand many times.  This tool was made for the task!!
I use a longish sewing needle with the eye end cut off to leave a fork shape.  Bit of polish/cleanup to remove burrs etc (so don't damage had finish).  Pop it in a pin vice and there you go.  Bit cheaper than Bergeon !!  I use similar needles for hairspring manipulation.
The idea of this tool is the blades have a flat side and round side, slide it under whatever you want to remove,  twist the handle and the blades twist too, rising higher and detaching the part. Two downsides; one the flat side leaves a mark unless protected, the other is the "lift" is not that far. So at some point you might want to pry a little, and on driving wheels (which these were initially marketed for) you end up often with a bent or broken pivot. I don't personally know any pros who use this tool, but do know some that just call it the "pivot breaker".
Maybe I misunderstood its purpose. I thought it was for easing the second hand by bending it slightly.  i would not use it for prying off anything as it could bust a pivot as is said. Only ever used this idea once on a particularly 'stubborn' new centre second hand and it did the job without continual removal to reshape.
I've only tried this once, but it worked.  My Waltham 0s pendant watch has one of the tiniest sub-second hands I'd ever seen.  And when I had to strip it for cleaning, that tiny hand had to come off.  All I could come up with was a doubled loop of my slenderest silk thread (I do quite a bit of sewing too) with the ends threaded through a small bead.  One loop went over the long pointer-end, the other went over the butt-end, and I slid the loops up to the boss, slid the bead down the thread to hold the loops there, and gave a gentle tug on the free ends.  The hand came off neatly and without damage.
Later on, it was a little beast to put back in place, being difficult to manipulate carefully, but coming off was a breeze.
    • I have it, so until we get a lunch one day , nearly everyday is with my mum at the moment.
    • In the meantime whilst awaiting a better plan, please drop me a quick hello on my email.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
