Sorting of forum
Hi,
in subforum "Watch Repair Tools & Equipment" I have a strange appearance.
Selected is "sort by: recently updated". But whenever I open this forum, I have to scroll to the very bottom to find the most recent threads.
That isn't ok, is it?
Frank
That is because pinned topics, (white icon by the title) are always shown first.
The reason why there are many pinned topics is that having them in good evidence may save members from posting a question about a frequent subject that has been discussed already.
To locate new postings try the unread content icon on top, it returns the section among other info.
It would be great if there was a feature that could be turned on that would un-pin pinned threads with no new posts.  So they would go back to their normal spot based on the age of the content.  One could turn it on after scrolling past the same pinned threads with no new posts for the thousandth time, at which point the purpose of pinning them, to bring attention to their content, has been long ago accomplished.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
