Making a Raised Jewel Setting
Following the Chicago School of Watchmaking Manual, somewhat, I made from scratch a raised jewel setting for a Ball Pocket Watch. I did this because the old setting had a broken jewel and the material to burnish was cracked on one side. I also put a video on YouTube and will share the link.
Steps
1. Source, size and chuck the stock material
2. Pick the jewel and using peg wood, stab it to hold it on the peg wood .
3. Drill a hole in the brass slightly smaller than the jewel. Make the hole long in case of do-overs.
4. Size and drill a straight hole just deep enough for burnishing lip.
5. Place the jewel in the hole with a little spit on the end so it stays in place.
6. With a very sharp needle like graver, cut a small trench just beside the hole and only to the depth of reaching the jewel. This will be your burnishing material.
7. Burnish in the material over the jewel. May need to make a tool for this.
8. Face off the setting up to the bent burnished material.
9. With a flat stake, lightly tap the burnishing material flat over the jewel. This is to just make sure there are not any raised edges.
10. Measure the old jewel setting diameter and then cut the Brass rod to a length twice its’ height and to its diameter. Hand fit the plate hole on the brass rod until it fits snugly.
11. Mark the height of the setting on the brass rod and shape the material to look like the old setting. Work slowly.
12. Cut away the new setting just above the height mark.
13. Place the setting in a jewel chuck, top side out and face off the setting to the right height.
14. Cut the inside material of the setting removing enough material and shaping to look like the old setting. Do not cut too deep or you will remove the top material holding the jewel in place. Using a polished steel rod, carefully burnish the inside of the setting until it shines.
15. Fit the new setting in the plate for final look and fit and adjust the top if needed again in the lathe.
That’s it. Thanks.
His a link to my 90 min video showing all the detailed technique.
Making a Complex Raised Watch Setting https://youtu.be/gkXw-JPnNPA
Steps
That’s it. Thanks.
  • Thanks 2
  • 4 weeks later...
    • Thanks, Jon Sounds like a plan. Obviously I'll have the face on so do you think gripping with the holder will create any problems, but I will check in the morning to see how feasible it is but I assume it only needs to be lightly held. As for holding the movement instead of the holder won't be possible in this scenario as one hand will be puling on the stem while the other pushes the spring down. That was my initial concern is how the hell can I do this with only one pair of hands. All the other times I've had to remove the stem hasn't been a problem, apart from the force required to release the stem from the setting lever, but now I need to fit the face and hands its sent me into panic mode. If it had the screw type release things would be a lot simpler but that's life 😀
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
    • Before putting it back in the case I would fit the hands and use a pin vice on the stem to make sure the hands were in line.
