Magnifying visors: eyes crossed!
So I just wanted to say "thank you" again. The angle is the key bit it seems and yes, it did basically just fall, or float, back into position when I got it lined up just right.
By transporter · Posted
Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks -
Hello Horologists, thought I'd introduce myself. I'm a 50ish year old who has been dabbling in watches for a while, did a couple of BHI course here in the UK and have started to dabble at bit more. I also took the level 1 course, which was a good refresher. Now off to look at some Bergeon tools and then buy (and regret buying) the cheaper ones... Stirky.
Hi All, I thought I'd draw a diagram to help me understand the motion works for an eta 6497 so I thought I'd share it here in case anyone else finds it helpful. Any corrections, please let me know! Hope it helps. Stirky.
