France Ebauches FE 233 69
Does anyone have experience with France ebauches, specifically 233 68 or 69? I have tried lots of different hour wheels and including different cannon pinions. Initially when I wind crown to set the time it is holds quite stiff, however after a few winds it's becomes very loose and loses time on the minute hand. I've tightened the canon pinion again and again but the same thing keeps happening. Its becoming very frustrating now as I've feel like I've tried everything. I'm not about the 4th new cannon pinion and 4th new minute wheel. None of them seem to keep hold. Any advice or has anyone serviced this specific movement?
Pictures are always nice of the movement because we might spot something without having to look up what it is you have.
I found the parts lists looks like a normal watch?
How are you tightening the Canon pinion. Are you using any kind of lubrication on the Canada opinion itself?
2860_FE 233.69AD,233.68AD21-1.pdf 2859_FE 233.68,233.69A,233.70A.pdf
Some FE233.69  were branded as Cupillard , I doubt if parts to the minute train or canon pinion are any different?
Did you grease  or oil the center arbour-canon pinion?     Perhaps center arbour is badly worn or you are not tightening the canon pinion enough.
Hi, I tried using d5 on the centre arbour and I've tried it with nothing on it at all. Yes Cuppilard and FE are one and the same. I've tried different cannon pinions and centre wheels which is what seems strange. I've tightened the cannon pinion really tightly to the point it is difficult to turn but after a few seconds of winding it just becomes loose again
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
