DIY Oiler cup
I need more oiler cups--I only have one.  So I had this idea to make one.  I don't have any agate lying around.  Even if I did, I do not have the tools to create the dimple.
Suddenly it came to me!  An acrylic watch crystal could be the cup.  All that I needed was some way to mount it.
Ahhh...the 3D printer.
Then to add some weight, I scavenged an old watch case from the scrap pile.
Here it is on the left.
The crystal came from the scrap box--smallest ladies watch I could find.
Thoughts??
What about a glass watch crystal? I know they come in really small sizes. I have an aversion to plastic for oil cups. You never know how the oils, react with the plastic and when you stick your Oiler in there's the chance of touching the plastic and generating plastic dust in your oil.
I wonder if you could find a watch case that has a removable bezel+crystal to use as the lid.  Cut down the bezel gasket, or lip if no gasket, so it's not a press fit anymore.  Then you could see the oil inside with the lid on and it would look more like a watch.
A small double dome glass crystal is just a buck or two, but I think you lose points if it's not entirely made from scrap parts.
LOL...gonna have to work on it ?
38 minutes ago, LittleWatchShop said:
After all said and done...I really want this.  Why?  It is beautiful.  The cups are ruby.  Will it make a difference to an amateur like me?  No.
Worth to mention that in this case the bling factor comes to the tune of GBP 315 + 20% VAT.  But if one can live with unpolished item then the cost be just USD 30
 https://www.aliexpress.com/item/1005001405391784.html
Does it come in a pretty a Yellow colored box like the other one if not it's crap.
Do we know what the oil cups are made out of? In others glass very acceptable plastic not acceptable
Then there's this one it's shiny has oil cups that look like they're made out of stone but I'm sure there glass which would be fine plus there really cheap
https://www.ebay.com/itm/Oil-Cup-Stand-with-4-Containers-Tool-For-Watchmaker-Watch-Repair-Tool-US/293913922938?hash=item446ea28d7a:g:4ukAAOSwd2deFYyu
Sad the time we live in now? Not finding what I like? Originally made out of wood originally they would have had Agate Later ones were glass. Then the last ones I saw plastic covers with wooden bases and of course glass. I've attached a photograph. The reason I like these are you can physically move them close you can see what you're doing when you dip your oil are in. I do see that expensive Swiss company has colored plastic ones with possibly class inside at astronomically huge prices there seems be no in between no inexpensive single oil cups unless the plastic.
Then in case you destroy your Agate Cups they have replacements? I don't quite understand the pricing though why ceramic cost more than Agate?
https://www.cousinsuk.com/product/oil-reservoirs
I have stopped trying to make sense of Swiss tools prices, and for the most part stopped buying them altogether. I just want the work done and if the Indian or Chinese item does it, that's what I'm buying.
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
