Movement Identification
yes, measure the old spring (length, width, height, thickness, barrel size) If you can't get the exact size, you can substitute a different spring if the critical dimensions are the same or compatible.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Ebosa_65
Mainspring: 1.50 x 9.5 x 0.11 x 290mm
Either of these would be suitable:
1.50 x .11 x 280 x 8.5 Non-Automatic GR4148
1.50 x .11 x 300 x 9 Non-Automatic GR4149
Lots of posts available here on replacing springs
