Very confusing Timegrapher results
Can you spot the difference between the first and the second picture, and no, I do not mean the significant improvement in amplitude?
As it turns out, the only difference between the first and the second picture is that in the first picture the movement is mounted directly on the microphone stand, whereas in the second picture the movement holder is mounted on the microphone stand.
Again, the amplitude goes from bad to (sort of) acceptable when the movement holder is placed on the microphone stand. Coincidence? No, I tried it on and off the movement holder several times, and very consistently the amplitude increases when the movement is in the movement holder.
I can’t make any sense out of this, and I don’t know what the true amplitude would be. I can only guess and that is of course quite useless. Anyone having had the same experience or care to consider what the cause might be?
The movement is a just recently (and meticulously) serviced and adjusted Omega cal. 268, so I’d like to think the 300 degrees is closer to the truth, but I just can’t get it verified. Very frustrating!
As JohnR725 always says with timegraphers; rubbish in is rubbish out. The microphone receives a signal, passes it on to the processor and it's up to the software to make any sense out of it. It may well be that a movement, clamped in a movement holder and subsequently the combination is clamped in the microphone creates additional vibration or resonance (?) If that would be the case, the software may or may not correctly interpret the received data.
Which one is correct? My two cents; as per design, the movement directly in the microphone.
Do I know for sure: no I don't ?
Edited by Endeavor
I agree the movement on the mic directly is probably the right one. This is probably one of the significant differences between these machines and "real ones" at 15x the price, the real ones seem to have a bit more sophisticated circuits that filter things better. I'm sure John will chime in, and he has experience with both- I just have experience with Witschi and then numerous old paper tape machines, haha. I did have the add on meter for those to see amplitude though.
I guess it makes sense but then again, this movement has been very carefully serviced. Everything is spotless, no hiccups in the train, pivots burnished where required, end-shake meticulously adjusted, the HS bouncing evenly between the index pins, and so on. Hmm...
New main-spring?
I wish I could come up with an answer to make your day ...... ?
How about filming the balance wheel with your iPhone in slow motion? With a video editor you can slow the video down even further. With a bit of luck, keeping an eye on one of the balance wheel spikes, you can spot the difference between 240 and 300 degrees?
That sounds like a brilliant idea. I'll give it a try as soon as I can (hopefully within a couple of days) and will report back.
And yes, a new (Generale Ressorts) mainspring was installed.
Edited by VWatchie
Answer is quite simple. The noise is too quiet with mov holder (for this TM).
Tick noise consists of mainly 3 pulses, the first being by far the lowest (most times). If the TM misses the first, it takes the 2nd as start of escapement time, base of ampl measurement -> detected esc time too short -> amplitude value too high!
Didn´t I explain that just recently?
Frank
What does it do if it's missing a beat entirely though? In that case, it shouldn't have enough data to calculate all the parameters it's outputting. They're based on timing relative to one another, not relative amplitudes ("distance A-C" from the above graphic).
What is the difference between the movement on the mic and the movement in the case on the mic? If praezis is correct, it should be similar, or at least a step along the same trajectory.
If you want to get really nerdy, what is the mass of the movement holder vs. the mass of the case (relative is all that's necessary)? I would expect a similar result along a linear curve vis a vis mass delta. F=MA, where the more massive of the case/holder requires more force to accelerate (pass sound through). There's technically more at play, but the basic mathematical relationship should present itself in the results. We would know the relative masses, and the relative amplitudes (based on whether or not or with what degree of reliability the timegrapher catches the signal). Force should be based entirely on state of wind, and thus essentially constant. If the relationship holds, praezis's answer will be all but proven.
@praezis; I know we digress from the topic and perhaps that's how a timegrapher works. You may be 100% correct, but it doesn't make a lot of sense to me. It would make far more sense to me if the TG would measure the time in between the 3 pulses and the next set of 3 pulses. The way you explain the workings (and therefor VWatchies problem), the TG would measure the speed (=time) with which the impulse jewel performs the unlock till the final lock over the duration of the lifting angle. This would mean that the higher the amplitude, the greater the speed of the impulse jewel. All well, but what about the beat error?
If the time was measured between the last pulse, the lock, till the next first pulse, the unlock, that IMHO would also tell something about the amplitude and gives an indication of the beat error.
Edited by Endeavor
I'd agree that it would be best to visually confirm the amplitude, either with a slow-mo video or with an easily removable mark (like a UV ink dot on the balance wheel arm).
For what it's worth, out of curiosity, I just found identical readings with an old Rockford pocket watch mounted directly vs mounted in a movement holder.
There are several features missing on the Chinese machines that would be really nice to have. Like audio interesting when you listen to the watch ticking if there's other noises like hairspring is bumping into things. Another useful feature found on expensive witschi timing machines is our oscilloscope mode. Any time I have anything that looks weird I go to the oscilloscope mode. Then you can look at the waveform it never looks perfect like the one above. Then the example above is not technically correct there actually five sounds two of them overlap with two of the others. Unless of course you're having problems and then you start seeing those also. So with the witschi in our oscilloscope mode it also puts a line where it perceives locking is occurring. As stated above the amplitude is measured from the roller jewel hitting the fork and locking or basically unlocking to locking. The initial roller jewel hitting is super quiet sometimes it's not quite contributed correctly. Or locking that's really allowed that should be super simple but a lot of times which he gets confused. I'll see the amplitude goes 300 to something lower as it keeps jumping around where it thinks locking occurs. Basically of the timing machine cannot get a good clean signal you're not going to get the results you desire.
I see somebody beat me to the answer again up above you can use the video to help for this. There's a procedure for finding lift angle where you mark the balance wheel you adjusted 180° to figure out what you lift angle is. But as you already know what the lift angle is you can also use this to verify that the machine is correctly indicating 180° visually at 180°.
A suggestion in your first picture the crown is sticking off in some random direction I find it's more useful if you would stick it out the end as it makes it easier to keep track of which position you're in. Once you've done that why don't you rotate the microphone to crown down and try it with the microphone and with the movement holder and see what happens.
https://youtu.be/-Xgcck692js
Then these phenomenons you're seeing are not always unique to things like this for instance if the watches in a case it doesn't always transmit the sound perfectly through the case. I've seen this several times with Seiko is at work or heavy Rolex cases. The Seiko is I think because the relatively quiet and a using a plastic movement ring. The basically on the machine they look like well crap. Take the movement out to you get a beautiful line and its nice at least for Seiko. Sometimes the timing machine has an issue they're not perfect this is where the additional features of audio to listen to things is helpful the oscilloscope is nice to see if you can even see a decent signal. When you start seeing signals where you start seeing for parts of the signal you know you're having a problem but the timing machine doesn't have the brains to interpret on oscilloscope and it will just attempt to give you numbers and they may not always be happy number is because they're not looking at the correct part of the waveform because it can't pick it up correctly.
  • Thanks 2
I was thinking about this discussion when I was at work today. If I knew ahead of time I would've taken a USB drive because I can do screen captures it look really nice verses a photograph but even in the photograph I think I'll get my point across.
You'll notice the waveform doesn't match the ideal perfect shown farther up. Also the timing machine puts a dashed line where it thinks locking is supposed to be. If you saw the full screen you'll see that there is two waveforms on top And two on the bottom and the only place where it will put the dashed line is on the first two of each line. So where I have the picture of both of them you'll notice once again the image waveform is not perfect like we always see it and the dashed lines are not in the same place.
Then when I was in our oscilloscope mode I was also looking at the amplitude. It kept changing just because the timing machine was being confused. The numbers were alternating between 245 and 277.
@Endeavor
Your description of amplitude measurement was correct, that's how it is done in TMs. Velocity within a fixed (lift-)angle.
- rate is tested as time between different noises and averaged
- beat error the same (and has nothing to do with amplitude)
- amplitude is tested as time between pulses in the same noise.
Frank
Thanks for you elaboration !
Probably not measure by the TM, but if an escapement was servery out of beat, wouldn't the amplitude to one side not be different than to the other side? To my mind with a watch in beat, the impulse jewel sits in rest on the center line which runs between the banking-pins (sides). With "out of beat" the impulse jewel does not and therefore to one side of the rotation the hairspring is already tensioned when hit by the fork, whereas in the other direction the hairspring is still "un-coiling". This, to my mind, should have an influence on the directional amplitude. Perhaps not the "overall" amplitude measured by the TM, but resulting in an amplitude difference between either directions. This would make the amplitude not completely independent of the beat error.
Am I talking sense or non-sense ?
@Endeavor
no nonsense at all!
Technically a heavy beat error may influence the amplitude, but TM test of both is independent.
Amplitude display is the average of right and left swing, with B.E. one is wider, the other equally smaller.
Frank
Are these the only two ways in which you clamped the movement?
Everyone seems to have headed off in the direction of the timegrapher pick-up/algorithm problems in reading the signal etc. which it could possibly be. I've had different readings dependent on how my movement is fixed in the holder and it's orientation to the metal part, which is the mic. I find having the escapement as close to the mic (metal part) is always going to improve the signal, especially if the gain is turned up as well
But, without knowing any other variables, such as, did you try different positions in both the movement holder and directly onto the pick-up and clamp, then they can't be ruled out. You may find that the pick-up and clamp are brushing slightly on the barrel teeth, or the movement holder presses on the side of the balance cock to lift it so slightly to increase end-shake and thus squeeze a bit more amplitude out, because there was a slight bind to begin with.
I'm playing devil's advocate, here. But it's good to take a different tack on the problem
16 minutes ago, nickelsilver said:
Don't these have a gain adjustement? I put movements in movement holder on my Witschi all the time, but every now and then have to adjust the gain.
Oh yes, they do, but I never tamper with it. Not that it is difficult (it's just pressing an up and a down button) but as I've been unable to fully understand its purpose I haven never changed it. The manual (Chinese to English via Google translate) didn't make much sense. Take a look at the last picture in my first post. The machines automatically switches between showing BEAT and GAIN every 10 seconds or so. So, move the green "progress bar" to the right to increase sensitivity and to the left to decrease sensitivity? And, what should I look for? Changes in amplitude I guess, but when do I know I have the "correct gain"? ?
The point of gain is to increase/decrease the amplification of the signal. If the suspicion is that it's not picking up part of the waveform because it's muffled by the movement holder, turning up the gain may bring it back into a readable range. The flip side, is if you're in a loud room or something and you're getting interference with the reading, you can turn the gain down to hopefully reduce that interference with your reading.
Much appreciated and your points could very well be significant. I'll have a go using different positions once a get a chance to.
Or perhaps amplified by the movement holder!? Anyway, I hope to be recording the slow-motion video tomorrow and publish it here.
Perhaps I should mention that my Omega 268 is a rather loud sounding movement. The ticks can be heard within 25 cm of the movement in a quiet room.
Edited by VWatchie
As if it is not complicated enough, another variable in the mix ! How good / sensitive are you ears? ?
Yes, but the release noise can still be silent (remember one of several in a tic).
Sometimes so silent that it is hard to separate it from random noise. In that case I don't expect much help from more amplification, as both are amplified.
Lets see what the video can tell ?
Frank
    • Got another one today! It took 10 weeks, but finally arrived. Fairly complete but I added the pivot guage. The burnisher and bow came with the tool. The case is a bit rough and the tool pretty dirty, but trying to decide how much I want to restore.
    • OK, so long story short, I'm working my way through Mark's courses using a "Sea-gul ST36" (or ST3600 from some vendors) AKA an ETA 6497 clone. as a practice piece.  I've had it fully appart and cleaned it, and have had it fully back together an "running", but only briefly as my oil hadn't arrived at the time.  In the course of that work, I saw no markings on the movement that would tell me if it was a true Sea-gul or just a clone of their clone of the original ETA movement. Well, fast forward to this weekend, when my oils arrived in my mailbox and I sat down to try my hand at oiling.  Everything was going swimmingly until I got to the shock setting on the top of the balance cock.  I was able to open the lyre spring without issue, but in attempting to swing the open to access the cap jewel and chaton, I apparently accidentally pressed the launch button as I sent the lyre spring into low earth orbit.  Like most things that make into such orbits it came back down at a place not too far from where it started, but of course that also means that it is no longer in the setting. So my task is now to get said spring back into setting.  What I have read so far tells me that I seem to have two options: Another thread here seems to indicate that the spring came out without taking the balance cock apart, therefore it should go back without the need for that procedure.  That seems a bit pie in the sky for me, but the posts in said thread also gave some high level information about how to get the spring back in (putting it at an angle to the channel cut in the cock and canted so that the tabs fit in the slots, followed by some "wiggling" to get it turned around the right direction.)  I've tried this a couple of times, which have lead to more trips to low earth orbit, but with successful recovery of the orbital vehicle after each trip.  This thread also suggests that what I did to cause the initial launch was to push the spring "back" with more pressure on one side than the other, which put it under tension and caused it to deform out the slot either on one side or at the end (where there is apparently no "back stop".) The other option appears to be varying degrees of disassembly of the balance cock.  Some things I've read suggest that the whole shock setting needs to come out, while other threads here suggest that I only need to remove the regulator arm and the arm carrying the balance stud.  After the last trip the spring made, this is seeming like a better option, but I'm super short on details on how to do what needs to be done.  if I am following correctly: I need to loose the balance spring stud screw so the stud is not held in the arm. I need to somehow disengage the balance spring from the regulator (all the regulators I've seen in videos look nothing like what I see on the balance cock I have.)  What I've seen on the interwebs is a couple of "pins" that the spring passes through.  What I see on my assembly is something that looks more like a single pin with a "V" shaped notch cut in the bottom of it.  The spring is secured in that notch with something that I guessed was glue, Posts here suggest that on some of these movements glue is in fact used.  So I'm trying to figure out how to tell, how to soften dissolve it (I'm guessing IPA or acetone) and how to put it back when I'm done (superglue?  UV glue?) With the spring detached from the cock, I've read that the regulator and stud carrier are basically glorified C clamps around the shock setting and that one removes them by slipping a razor blade under one side of each and prizing them up.  I assume that they go back in the reverse manner like another C clamp, but that again is only a guess.  The place I got this information from seemed to leave that bit out. Once I have one or both arms off the shock setting the above mentioned post seemed to indicate that I could just slide the spring back in the slot, though again, I'm interpolating between the lines I read.  The alternative that I've seen demonstrated on high end movements on Youtube is to remove the entire shock setting and to replace the spring from "underneath" rotating the setting so that spring basically falls into place. I'm not anxious to try this method, as I don't have a jeweling tool to put the shock setting back into place.  That not to mention that the professional watch maker who did the demonstration described "fiddly work." So at the end of the day I'm looking for a little guidance on which pathway to follow, or if I've missed something obvious, a new direction to follow.  If this is a repair that just need to wait until my skills improve I'm totally good with that, I can get another of these movements in relatively short order, I just don't want to treat this one as disposable, and I do want to make an honest effort at fixing it and learning from this experience. Thank you in advance for reading my ramblings and for any suggestions that you might have!
    • All the best, family always comes first, and I believe you have made the right call that you mother deserves your full attention. However, when you need a little outside distraction the guys here will always be available for some banter or a heated discussion on lubrication 🤣.
    • Wire for what? if it's steel then only certain types of steel can be hardened ie high carbon steels: "Mild steel doesn't harden very well. It doesn't have enough carbon. Get something like O1, silver steel or if you want to go full watchmaker, then Sandvik 20AP". Source
    • I'm wondering if there's any specific type of wire I should get for hardening? I would assume it doesn't matter as long as the wire doesn't melt before it is at temp.
