Legarm
Cleaning Solutions, UltraSonic and not
15 hours ago, praezis said:
Do not use naphta at all, it may explode (if it is what we in Germany call 'Benzin')!
I use Elma 9:1 myself and I am satisfied with the results. 2nd jar destillated water, 3rd jar Isopropanol.
Frank
Thanks Frank. Shellite/Naptha is very similar I think to Benzene. It certainly did concern me that an electric motor was running directly above that very flammable solution! What do you do with the pallets and hairspring when it comes to jar 3?
Share this post
Link to post
15 hours ago, Tmuir said:
Shellite is good for the rinse, but you do really need proper cleaning solution for the initial wash.
I use turps 70% to 80% shellite 20% for the first rinse and 100% shellite for final rinse.
At my watch cleaning school we make our own watch cleaning fluid, but its not really practical to make your own for just yourself as some of the active ingredients and very expensive and unless you are making 20 litres or more it isn't worth doing.
Unfortunately there really isn't an alternative to buying the real watch cleaning solution, but save yourself some money and skip buying their rinse.
Where in Australia are you?
Thanks for the tips. I'm in Sydney. Is the fluid you make water based? Do you think running Shellite in the machine/jars is safe given what the other poster has just said, as there is an electric motor running very close and these can generate sparks. This is possibly a 40 year old electric motor and the brushes on these are probably not great.
Share this post
Link to post
I'm in Perth, so the other side of the continent.
I'm yet to get hold of a traditional watch cleaning machine so at the moment just use an ultrasonic cleaner with the fluids, but we use the same fluids in school in a machine like yours.
I can't comment on your specific machine, I will leave that to your own judgement on how safe you feel it is to use it.
The fluid we make for cleaning watches is also identical to the branded cleaning products and is a non water based cleaner.
For clocks I use a water based cleaner, but not for watches.
If you go look up the SDS for L&R cleaning fluids you will see for both their cleaning and rinsing solutions they contain around 20% shellite. (With the rinsing solution basically being 80% turps 20% Shellite)
The only reason I use 100% shellite for my final rinse is it evaporates much faster than the 80% turps 20% shellite mix.
But I am very careful to not to have the heater on and I only use small amounts in a jar in a bath of water that I change for fresh water once it heats up to about 35C with the ultrasonics.
You can probably get away just using the 80% turps, 20% shellite for the first and final rinse as your machine will spin off most of the fluid, something I can't do with an ultrasonic machine, which is a less volatile solution to just straight Shellite.
Share this post
Link to post
L&R #111 Ultrasonic Cleaning Solution is a cleaner and needs to be followed up with a rinse.
L&R #3 Watch Rinsing Solution is a rinse and should follow a cleaning bath.
Neither is an all in one cleaner and rinse combined.
Share this post
Link to post
If you need to save money for the rinse you can follow with the first rinse of 50/50 Turps and Shellite (Lighter fuel - Naphtha ) and a final rinse of just shellite. Just be very careful as Shellite is very volatile so keep an eye of temperature in the solution and don't use a heater.
This is only for if your cleaning solution you are using is a waterless cleaning solution
Share this post
Link to post
The problem I have found when using Turps/lighter fuel/petrol etc is the fumes. A real problem if your workshop is in your house.
For me after a lot of experiments the L&R solutions are the best in terms of cleaning results & they also have very low fumes.
Share this post
Link to post
I use lighter fluid in small plastic pots with a lid - just enough to cover the parts, sat in warm water in my (very small) ultrasonic.
I then 'rinse' using isopropanol as naptha leaves an oily residue.
I don't smell any fumes.
Share this post
Link to post
Although I'm new to this forum, I've been repairing pocket watches under the guidance of Donald De Carle and various blogs for some time - I have always utilised an ultrasonic cleaner and various solutions produced specifically for use in ultrasonic machines when cleaning components, but I'm beginning to grow tired of my shed reeking of ammonia, as well as the general expense of these solutions, and the often poor results (this is perhaps largely due to it being a very cheap ultrasonic cleaner).
I've decided that it may prove better to stick to the traditional and time-honoured method of using benzine (also known as 'petroleum ether', easily found on a well known internet auction site using those search terms) and various brushes/pith/pegwood - This is covered fairly comprehensively in De Carle's 'Practical Watch Repairing', and allows you to be a little more meticulous (although it's time consuming) in the cleaning of components.
Will the benzine damage shellac/pallet jewels if exposed too long, or is it relatively safe to use it for brief periods?
Share this post
Link to post
I've used naptha for a long time on all types of mechanical watches and have never had a problem with the pallet jewels. The pallet stones should still be cleaned in ultrasonic solution as naptha doesn't dissolve dirt or dried/caked oils. I'n my experience, naptha or VM&P naptha, is best used as a final rinse because it dries quickly and with no residue.
J
Share this post
Link to post
Or course is is safe, otherwise De Carle and all the other watchmakers of the past and present would not have used and recommended it. There are various threads on the subject already, easy to find using the search box right.
Edited by jdm
Share this post
Link to post
I clean all the parts in naptha in the ultrasonic, as it does not dissolve shellac. I then use isopropanol to remove the oily residue, but for the pallet and balance, I only do a few seconds in the ultrasonic as it does dissolve shellac.
I'll drop an old pallet in some isopropanol in the ultrasonic and time how long it takes to dissolve the shellac.
Share this post
Link to post
Same here, but for an quicker way, tried rectified benzine (or petroleum), which leaves no residue. Interestingly, I could not find a direct hit or common name for English speaking countries, but is easy to find in mine, where it's even sold in pharmacies, to be used as solvent, or stain remover. Material houses also carry it.
Share this post
Link to post
I've never heard of rectified benzine in the UK. I wasn't aware of benzine, only benzene, which is an additive to petrol and carcinogenic, so stuff to keep clear of.
The term Naptha seems to cover all sorts of petroleum distillates. All very confusing.
Share this post
Link to post
Yes, petroleum names are for utter confusion. For the chemist https://en.wikipedia.org/wiki/Petroleum_ether In the end we're talking about rectified version of what in Argentina at the pump it's called naptha. Gasoline in the US. Petrol in the UK. Benzine in my EU country. Essence in France.
Share this post
Link to post
Assuming we can post links on this forum, this is what I'm using: http://www.ebay.co.uk/itm/Petroleum-Ether-40-C-60-C-1-Litre-Petroleum-Spirit-Same-Day-Shipment-/141226080247?hash=item20e1baf7f7, since I only repair four or five watches a year (just as a hobby).
I chose one with a lower boiling point, since my chemist friend tells me that although it's a little more volatile (it's EXTREMELY flammable and should definitely only be used well-ventilated/away from sources of ignition - I even go as far as only using it in natural light), it proves a better solvent. It's frustrating that they attach the label 'petroleum spirit' to the listing, which makes me think of glorified paint thinner, but from my understanding, it's a little more refined (distilled to a greater extent) version of the same thing.
Although both harmful, definitely best not to confuse it with benzene, haha.
Share this post
Link to post
Loading...
    • Yes, I think I'm gonna do that.  Thanks!
    • Looks like a fun project. I suspect there is little that would stop it passing modern electrical safety standards, so long as it is earthed, has the correct rated fuse, and a suitable mains cable attached. How does the speed controller work? Some of these old speed controllers use an interesting arrangement of compressible carbon disks as a variable resistor. I have an old Singer sewing machine that uses this arrangement, and a slightly newer Kenwood Chef mixer that uses a triac speed controller. Both are 1970s vintage, and both work well. I would inspect any capacitors associated with the motor assuming there are any, and perhaps replace those with modern suitably rated ones, but the rest I would suspect is fine. If the motor runs, then it will probably keep running. If this is a brushed motor, you might like to take the opportunity to clean the commutator with a bristle brush (not a steel wire one) and inspect the motor carbon brushes too. If the brushes are badly worn or damaged, they can kill the commutator pretty quickly.
    • When working with small metal parts, (not necessarily watch parts, but this applies with those too), I will superglue the part to something I can easily hold, for example plastic card stock, or some other metal, then file away, drill, etc.  then dissolve the superglue in acetone to remove the part.
    • A bit of a classic Timex. So much so that Timex recently released a Snoopy version of the new Miyota automatic based Marlins, and a bunch of other self homages in the Peanuts Charlie Brown, Snoopy & Friends range. This more petite version, I'm guessing from the mid seventies, is the one I remember from my childhood, blue dial and all. It is heading in my direction as a "non runner" (no surprises there), and I was the only bid at £1.93
    • I have recently purchased a National, Electric Watch Cleaning Machine. Attached is a photo for reference and identification of the model type. As can be seen, it has a fairly typical design, reminiscent of many other types, particularly Elma Super Elite. In fact, I do wonder which came first - the National or the Elma. My musings on this point later. This is a very old machine, circa late 1940’s, 1950’s, but they seem to turn up sometimes on eBay, in various conditions ranging from the “beyond hope” and only really suitable as a donor for parts, and the “old but serviceable” and might-be-worth-a-punt-on machines. This one fell into the middle somewhere, as it was a bit tatty and the heating element did not work. On the plus side, it had all its original cleaning fluid jars and lids, and the motor and speed control gave smooth, controllable spinning and no play in the bearings. I went to visit the seller to inspect it and we did a deal on the spot. This is not always possible on eBay, but as the seller had listed it as for collection only (due to its weight), it was a possibility on this occasion. Once I had it home and gave it the once over, I decided that I would have to either do without heating for the drying stage, or find a replacement element. At the same time, it was very obvious that all of the original cabling was not safe to leave in place and it would all have to be removed and replaced. Any other electrical parts deemed unsafe would also be replaced as I inspected them. So - the idea of a restoration (of sorts) was born. Now - it is not my intention to restore it to the point where it could pass current electrical safety standards, but I will be making it as safe as possible, without losing any of the essential character of the original machine. This is not going to be for resale, so being safe to use is an acceptable compromise, in my opinion. I will however, perform testing on it once the electrical work is done, to make sure that the essential aspects of earth leakage, earth bonds and polarity etc. are passed. (PAT Testing included.) Whilst this is not likely to turn into another example of a superb restoration of an Elma Super Elite (as seen elsewhere on these forums), I hope at least to have at the end of it, a perfectly serviceable watch cleaning machine, and a restoration story - of sorts - of a vintage piece of English watch making and servicing machinery. So first off - the before pictures. This one is a good view of the machine and its cosmetic condition, as purchased. The base is a heavy, cast alloy jobbie, with its original crackle paint job beginning to flake away in places, where the years of cleaning chemicals have attacked it,  but generally sound. The jars still had residues of cleaning and rinse chemicals present. The first wash jar (front left), was particularly grotty and can’t have been cleaned for years. Fairly ironic not to clean the thing, that cleans the things! Maybe it was just left unused and unloved for many years. The mains cable was a cloth-bound type I have not seen in years and could well have been original as it still had the old UK wiring standard colours of red/black/green. Also adding to the vintage-ness, was a very old, Bakelite three pin plug. This must have been one of the first of its type as I have not seen one in brown Bakelite before! (And I am 62...) Anyway, that’s enough for now, as I’m not even sure anyone wants to read much about such an old machine. If anyone is interested though, please add comments and I’ll add to the story as I make progress. At the very least, I hope I have found a potential solution to finding/ making your own heating elements for these old machines, which could also include providing replacements for Elma Super Elite, RM80/90 HCS511 etc. Machines. More details later...
