Legarm
Cleaning Solutions, UltraSonic and not
I clean the balance and hairspring mounted on the main plate. I rinse off the cleaner by submerging the plate in a basin of water at 50 degrees centigrade for about ten seconds, then blow off the excess water with a puffer. The plate is then placed in a container with alcohol and agitated with the puffer for about thirty seconds. I then remove the plate and place the plate onto a folded piece of kitchen roll to absorb the majority of the alcohol and gently use the puffer to blow air on the balance until it starts to swing correctly. At this point I remove the balance from the plate and store it separately until assembly. It is only at the point of assembly that I remove the balance jewels and clean them separately in lighter fuel.
Share this post
Link to post
Thanks for the detailed steps Geo, I assumed that would be the way to go, leaving the balance on the mainplate etc.. Just got confused, as Bogdan suggested not to clean the balance in alcohol.
Sent from my SM-G920F using Tapatalk
Share this post
Link to post
Do not soak the balance for any great length of time if you will could have a problem with the roller jewel. That's why I say to dip it only for seconds before puffing it dry.
PS I have been doing this for years when cleaning parts in the ultrasonic tank and have never had a problem.
Share this post
Link to post
I have a question @Geo.
You clean the balance assembly put on the main plate and only at the end you take off the balance jewels and clean them separately.
How are you sure that you sufficiently cleaned the balance pivots. I believe hardened oil and dirt could remain on it (between it and the jewels). This is why, if I had a machine, I would wash the ballance on the main plate, but without the jewels on.
Thank you,
Bogdan
Share this post
Link to post
Hi Bogdan.
If it is a really dirty watch that hasn't been serviced for years I will strip the movement completely then soak all parts overnight in naphtha (lighter fuel) to soften any hard oily deposits. This includes the main plate and balance assembly as separate units. The next day I will attach the balance to the main plate complete with balance jewels and clean them in the ultrasonic tank with ammoniated cleaner at 50 degrees centigrade for five minute, then rinse as previously described. This has always given a good result, and I feel that it is due to the pivots vibrating inside the jewels which aids the cleaning process. It will have a pistoning effect that I imagine should help wash out the muck.
After this process, I remove the jewels and give them another clean in naphtha just for good measure.
I might be completely wrong with my assumption, but the process does work with great results for me. Before using this technique, I had the odd issue with jewels and residual muck.
There are some watchmakers that do recommend removing the jewels as you described, but I don't.
Share this post
Link to post
This really has been extremely enlightening. Think I've finally got my head round the cleaning cycles & can see where I've been going wrong. It may even shed light on some of the issues I've had in the past. Thanks guys
Share this post
Link to post
Like George I have been getting on OK with Naptha for a while now and I use Isapropanol for the final rinse but my stuff is small scale as I don't really have a need to do anything in bulk. I do treat the pallets separately.
Cheers,
Vic
Share this post
Link to post
I recently bought a watch cleaning machine from a retired watchmaker, when I collected the machine the jars already contained solution, the watchmaker told me the rinse jars contained isopropanol. I did ask him what effect on the shellac holding the pallet jewels would the isopropanol have, saying I would be worried that it would dissolve. He said he had used it since Benzine had been unavailable to use, and as long as I rinsed for no more than 15min in each wash there would not be a problem. He also said it was very quick to evaporate in the drying stage and left no residue.
I have ordered new cleaning solution and rinse solution from Quadralene and intend to use these.
I have though cleaned 4 watches last week in the solutions in the machine and have not had a problem.
Today I decided to test and see how long it took to actually dissolve the shellac,
The image above shows 3 Russian and one Swiss set of pallets and the shellac can clearly be seen. I have been using the solution for 15min each rinse and have not had a problem so I put the pallets in a isopropanol rinse for 1hr  to see what effect it had
On the Russian pallets it has greatly degraded the shellac and almost totally washed it away on one, but on the Swiss pallets it has not even touched the shellac on those.
I will not use isopropanol again in a cleaning machine and intend to try a similar test with the Quadralene rinse to see how shellac friendly that is because the data sheet doesn't specify what ingredients are in it, but quadralene did tell me they have many watchmakers who buy their rinse and have not had any problems.
Share this post
Link to post
Great test & thanks for your sacrifice. It really does prove how in the wrong hands & without the correct information you could be left with a big problem.
Edited by jdm
Please don't include pictures in quoting
Share this post
Link to post
Thanks to WLS1971,
This chestnut has been discussed a lot on the forum but we now have some evidence thanks to your efforts.  Interesting how the shellac seemed to be of differing composition between Russian and Swiss.
Cheers,
Vic
Share this post
Link to post
I think isopropanol is safe to use if cleaning by hand for short periods, but I wouldn't use it in the machine again, the information given to me is probably correct in that 30 min exposure to isopropanol has little effect but at some point beyond that it softens the shellac, and once it's at that point it would attack it very quickly in the cleaning machine because of the constant agitation..
Why the shellac on the Swiss pallets was not effected I don't know they had exactly the same exposure as the Russian ones.
I cleaned last week a Sekonda pocket watch a Cyma pocket watch a Regency wristwatch with FHF movement and a ladies Lanco the exposure they received was 15min each rinse and there was no problem.
The only conclusion to be drawn from the test is avoid its use in a cleaning machine and don't soak or rinse beyond 30mins as a max which wouldn't happen any way if cleaning by hand unless you where distracted or forgot and left them too long.
Share this post
Link to post
Just to add when isopropanol dissolved the shellac on a pallet and balance impulse Jewel of mine , (mentioned above) this was 2 separate occasions and they were only in the solution for 480 seconds , the max setting on my ultrasonic cleaner.
They were Swiss movements , so whether it was a case that the vibrations from the ultrasonic loosened them or maybe the isopropanol was to pure at 99.9% I don't know , but I don't do use it anymore
Share this post
Link to post
That's interesting Andy, it's probably the extreme ultrasonic vibrations that exacerbated the problem. I only use it as a final rinse by dropping the parts in a jar of the stuff for about 30 seconds, I never use it in the ultrasonic bath.
Share this post
Link to post
Thats what i'm guessing Geo if people are using it for 15mins at a time without issue, i've still got the stuff , i'll experiment again using it as you do just as the final short rinse
Share this post
Link to post
Hello Everyone,
I am looking for a watch cleaning solution to rinse some pocket watch movement parts in. I do not have a ultrasonic cleaning machine. Would soaking the parts in an "ultrasonic" labeled cleaning solution work? Thank you very much!
Share this post
Link to post
darthdosh, I think you are getting too technical for me. :)
I would also recommend not to smoke while working on watches even if you are not using any of the different chemicals (for cleaning, lubing and other stuff), a small amount of cinder or any other debris from a cigar/cigarette can contaminate your work...anything can contaminate your work and your workplace. You must strive for a clean, dust free environment.
Cheers
Bob
Share this post
Link to post
Loading...
    • Yes, I think I'm gonna do that.  Thanks!
    • Looks like a fun project. I suspect there is little that would stop it passing modern electrical safety standards, so long as it is earthed, has the correct rated fuse, and a suitable mains cable attached. How does the speed controller work? Some of these old speed controllers use an interesting arrangement of compressible carbon disks as a variable resistor. I have an old Singer sewing machine that uses this arrangement, and a slightly newer Kenwood Chef mixer that uses a triac speed controller. Both are 1970s vintage, and both work well. I would inspect any capacitors associated with the motor assuming there are any, and perhaps replace those with modern suitably rated ones, but the rest I would suspect is fine. If the motor runs, then it will probably keep running. If this is a brushed motor, you might like to take the opportunity to clean the commutator with a bristle brush (not a steel wire one) and inspect the motor carbon brushes too. If the brushes are badly worn or damaged, they can kill the commutator pretty quickly.
    • When working with small metal parts, (not necessarily watch parts, but this applies with those too), I will superglue the part to something I can easily hold, for example plastic card stock, or some other metal, then file away, drill, etc.  then dissolve the superglue in acetone to remove the part.
    • A bit of a classic Timex. So much so that Timex recently released a Snoopy version of the new Miyota automatic based Marlins, and a bunch of other self homages in the Peanuts Charlie Brown, Snoopy & Friends range. This more petite version, I'm guessing from the mid seventies, is the one I remember from my childhood, blue dial and all. It is heading in my direction as a "non runner" (no surprises there), and I was the only bid at £1.93
    • I have recently purchased a National, Electric Watch Cleaning Machine. Attached is a photo for reference and identification of the model type. As can be seen, it has a fairly typical design, reminiscent of many other types, particularly Elma Super Elite. In fact, I do wonder which came first - the National or the Elma. My musings on this point later. This is a very old machine, circa late 1940’s, 1950’s, but they seem to turn up sometimes on eBay, in various conditions ranging from the “beyond hope” and only really suitable as a donor for parts, and the “old but serviceable” and might-be-worth-a-punt-on machines. This one fell into the middle somewhere, as it was a bit tatty and the heating element did not work. On the plus side, it had all its original cleaning fluid jars and lids, and the motor and speed control gave smooth, controllable spinning and no play in the bearings. I went to visit the seller to inspect it and we did a deal on the spot. This is not always possible on eBay, but as the seller had listed it as for collection only (due to its weight), it was a possibility on this occasion. Once I had it home and gave it the once over, I decided that I would have to either do without heating for the drying stage, or find a replacement element. At the same time, it was very obvious that all of the original cabling was not safe to leave in place and it would all have to be removed and replaced. Any other electrical parts deemed unsafe would also be replaced as I inspected them. So - the idea of a restoration (of sorts) was born. Now - it is not my intention to restore it to the point where it could pass current electrical safety standards, but I will be making it as safe as possible, without losing any of the essential character of the original machine. This is not going to be for resale, so being safe to use is an acceptable compromise, in my opinion. I will however, perform testing on it once the electrical work is done, to make sure that the essential aspects of earth leakage, earth bonds and polarity etc. are passed. (PAT Testing included.) Whilst this is not likely to turn into another example of a superb restoration of an Elma Super Elite (as seen elsewhere on these forums), I hope at least to have at the end of it, a perfectly serviceable watch cleaning machine, and a restoration story - of sorts - of a vintage piece of English watch making and servicing machinery. So first off - the before pictures. This one is a good view of the machine and its cosmetic condition, as purchased. The base is a heavy, cast alloy jobbie, with its original crackle paint job beginning to flake away in places, where the years of cleaning chemicals have attacked it,  but generally sound. The jars still had residues of cleaning and rinse chemicals present. The first wash jar (front left), was particularly grotty and can’t have been cleaned for years. Fairly ironic not to clean the thing, that cleans the things! Maybe it was just left unused and unloved for many years. The mains cable was a cloth-bound type I have not seen in years and could well have been original as it still had the old UK wiring standard colours of red/black/green. Also adding to the vintage-ness, was a very old, Bakelite three pin plug. This must have been one of the first of its type as I have not seen one in brown Bakelite before! (And I am 62...) Anyway, that’s enough for now, as I’m not even sure anyone wants to read much about such an old machine. If anyone is interested though, please add comments and I’ll add to the story as I make progress. At the very least, I hope I have found a potential solution to finding/ making your own heating elements for these old machines, which could also include providing replacements for Elma Super Elite, RM80/90 HCS511 etc. Machines. More details later...
