Legarm
Cleaning Solutions, UltraSonic and not
I use denatured alcohol to clean the "shellacky" residue that forms on the inside of watch cleaners' jars and SS containers. It breaks down that stuff easily and visibly cleanly.
I don't think that I'd use it on pallet-forks or balances with roller tables/jewels installed. But regarding your basic dilution of isopropyl found in drugstores around the world, is it safe to use as quick rinse on complete balance assemblies? I ask because I just serviced a little 7.75L GP wrist-watch and it's running quite fast. I had noticed that the hairspring was sticking together a bit after soaking in Coleman fuel, what I believe is naptha. It seemed like there was  still a residue left behind.
So, would I be safe, and effectively remove the residue, by swirling the balance around in isopropyl for a bit after soaking in naptha? If there's any question, I'll just have go get some more One-Dip. I don't like the toxicity of it, or that it seems to disappear in a couple of years even if you have the cap on tightly. Any learned help is appreciated.
The problem with these small movements is that each time you manipulate things, you get close to disaster. And it's a game of numbers. Cheers.
Edited by MrRoundel
Share this post
Link to post
Hello,
Wan't to start on my first pocket watch movement for a try out...
Planning on buying a Elma cleaning machine later this year, but for now I will do it manually.
Do I understand it right, that you put the parts in jars with 100% lighter fluid ( except pallets ) close the jar and put the jar in to the water in the ultrasonic? ( And then run as far as you can? :D )
Share this post
Link to post
Lighter fluid is for lighters as it contains oils, fragrances and other stuff that does not belong to contemporary watchmaking.
If you want the plates to shine give a first bath in ammonia based solution.
Then a bath in petroleum ether (refined naphtha) to dissolve oils, check jewels for cleanliness under the loupe.
Also useful is Isopropyl alcohol as final rinse and in some cases the only one.
All these have been discussed many times previously in this same thread, which you can read for further education.
Share this post
Link to post
Thanks jdm.
I read this post, but on the end, I din't see it any more. English is not my normal language, and all different things were recommended.
I don't mean lighter fluid, in my country we call it "wasbenzine" let's say "cleaning fuel"... ;-)
But here I can find different products I can use, to many to choose off:
https://www.beco-technic.com/werkzeuge-verbrauchsartikel/reinigungsprodukte/fluessigkeiten-zum-reinigen/fuer-uhren.html
Share this post
Link to post
Yes, refined benzine is petroleum ether, naptha, shellite, etc, but native English speakers will confuse it with benzene, and tell you that is toxic (true), so better avoid that term on an international forum.
Edited by jdm
Share this post
Link to post
9 minutes ago, Koen said:
Think I just going to order this machine and the right products:
As a beginner hobbyists you don't need an €2,000 automatic cleaning machine. The same and less money can be spent of important tools like timegrapher, bench case opener, water pressure tester, lubricants and even a lathe. You can get an economic jewelry ultrasound cleaner but event that isn't mandatory.
Share this post
Link to post
Hey jdm,
Thanks for your good advice.
Need to make some cost for my firm this year, so thats why I was thinking to buy it... And maybe later I make from my hobby a bit of an income, so good material is always a +. ;)
Also looking for this timegrapher:
https://www.beco-technic.com/geraete-maschinen/uhrenpruefgeraete-kontrollgeraete/geraete-zur-pruefung-von-uhren/witschi-watch-expert-pruefgeraet-fuer-mechanische-uhren.html
Maybe to much for a starter... but hey YOLO.
What watertester do you recommend? With water or vacuum?
https://www.beco-technic.com/geraete-maschinen/uhrenpruefgeraete-kontrollgeraete/geraete-zur-pruefung-der-wasserdichtheit.html
The ultrasonic cleaner I already have here... Use it for the jewelry of my wife. :D
Share this post
Link to post
If you have the funds buy a watchmaker lathe, accessories and learn how to use it. You may be become a good watchmaker as opposed to an equipped cleaner.
Share this post
Link to post
12 hours ago, Koen said:
Hello,
Elma cleaning machine!!!?  NOT .
I get me a staking set, set up a diy timegrapher ,lots of useful goodies you can get with that kind of money.
Share this post
Link to post
Thank you all for the advice...
So no cleaning machine.:D
But still need to spend my budget for the end of the year... if not, government is taking it and spend it for me... :chainsaw:
Share this post
Link to post
That is so easy in watchmaking, especially when buying Swiss tools that on many cases  work the same but cost four times the Chinese. But that's another story.
An other quick way to spend money is to buy  watches for practice. At the very first you can go cheap but ideally you want them to be of quality to be repairable, have parts available, and being of attractive brand and models to buyers to reseller later.
However money can buy tools but not knowledge, dexterity and skllls, for that reason beginners must focus on practicing on the bench as more they can. Also reading books is very beneficial although nodawaday enrolling into an online course like the one offered by our Host Mark Lovick is probably a better alternative.
Edited by jdm
Share this post
Link to post
So, I tried something to clean case an bracelet and it worked really well.
Plain water, detergent and corega tabs . Soaked two days and you can see the the result laying on the bottom.
Share this post
Link to post
I also have an old Elma, which I got at an Ebay Auction. I use the machine to clean the movements.
I bought the fluids from elma. 1st Jar for a cleaning solution and the 2 others for the rinse.
The parts come out if the machine really clean and shinning.  Its beautiful!
I'll try to post a pic tomorrow.
Share this post
Link to post
Loading...
    • Wow thats interesting I have a bag of flakes as well. BUM
    • Shellac is never useless Mark . From small drawers to large antique cabinets it's a lovely and rewarding material to work with.
    • So keeping them in a small dry draw in a cabinet which is  dark works.
    • Well that question got me googling... There is a lot of discussion about this on the ”interweb”, but mostly in relation to woodworking and nail polish! Shellac is a natural product, subjected to various purification processes prior to sale which have changed significantly over the years, so firstly, the shellac we buy today is likely to be much purer and more consistent than in the past. Shellac flakes sold for making wood finishes definitely deteriorate with age. After a period of time the can no longer be dissolved in alcohol. I haven’t found out exactly why, but moisture, heat and light are all cited as causes. So, keeping your flakes in a sealed dark container would be a good thing. Shellac in stick form will have a lower surface area for a given volume and therefore certainly less susceptible to moisture. Once mixed with alcohol, shellac will start to react chemically, (search for esterification if you want to know more), and evaporation of the alcohol doesn’t get you back to where you started. This is why pre-mixed shellac varnishes have a short shelf life. Shellac is chemically similar to acrylic, and hence made of long polymer chains. I’ve read conflicting information about whether these will cross-link in ultraviolet light (the process that causes unbreakable watch crystals to go yellow and brittle). However, I would expect it to behave in a similar way - again, this is a non reversible reaction. All of this may go some way to explain why some people reprt there is no problem with cleaning pallets in alcohol and others saying it softens the shellac. I’m now into this deep enough to need a good chemist to get me back out. Any volunteers?
    • This is asked very often. Especially when you have no experience it would be good to use a caseback opener, a good model below.. And then you need a case press to close it.   Skip on that and you have good chances to scratch or otherwise damage it it. So, all in all, it can be more expeditious to bring it to the watch shop.
