I'm fortunate to have an ACS900 cleaning machine and wondered how you guys would choose to fill the jars...
The user manual suggests:
Jar 1 - cleaning solution (I use the L&R #111 ultrasonic)
Jar 2 - cleaning solution OR rinsing bath. Which would you use?
Jar 3 - rinsing bath (I use L&R no 3 watch rinsing solution)
Jar 4 - cleaning or lubrication bath
Position 5 - empty
So, how would you fill jars 2 and 4? I'd be curious to know :)
Thanks!
There is a product that can be used as the final rinse, or added to it, which supposedly lubricates the watch and eliminates the need to oil. It was popularized in the 70s along with cleaning assembled watches. The dark ages of watchmaking.
Thanks, I think clean clean rinse rinse is the system! I'm not sure what the "lubrication bath" would be... is that a thing?
Hello all, my name is Jakob.
I recently got into servicing mechanical watches at home. My question is now what i need (at minimum) to be able to start cleaning (and oiling) parts.
I live in Sweden and can not seem to find any good cleaning solutions to buy. Is it a good idea to soak the parts in pure white spirit (mineral spirit) and then letting the parts dry? Is that enought?
Then when it comes to oiling, what oils is a must? Is it enought to but Moebius 9010 and some Moebius 8300 Grease? Do I also have to get Moebius D5 or do I have to get even more?
Best regards Jakob, if I posted this in the wrong fashion please guide me to the right place.
Hi Jakob and welcome to the forum, we’re a few Swedes here that show up now and then.
Also an amateur I use the ”kemiskt ren bensin” you can buy from your local grocery store (ICA, coop) . It comes in plastic 200 ml bottles and the brand name is ”Gripen”. They do acethone and other stuff as well.
These days you will have to find that special place in the store where they keep the inflammable stuff.
I use (with warm tap water and some washing up liquid, not the bensin) a cheap ultrasonic machine I got from Kjell & co. Works fine for me.
So far my entire lubrication supply consist of 9010/9020 & 8200 grease and that has worked so far. Thinking of getting some other grease as I find the 8200 a bit too liquid at higher temp’s.
1
I read that 8300 is used instead of 8200 at higher temperatures
I found this post to be useful. Especially the part about refining petroleum.
I really don't like using lighter fluid because the purity of it is a pot shot. I was using Publix Quick Light and it leaves a lot of residue. The problem here is that they aren't meant for cleaning things. They COULD be pure naphtha but they could also not be. It's depends on the brand and not everyone has access to the same thing. Also, I get dizzy when I stand over parts soaked in lighter fluid. I use acetone to rinse it off but it's still a PITA.
I try to find all my solvents at Walmart or Home Depot because I am cheap. But it's confusing as hell to figure out what these products actually are. They are named by convention and not chemistry, so names like "paint thinner" could mean different things to the manufacturer.
For example, Klean Strip sells "Paint Thinner" and "Odorless Mineral Spirits." According to them, odorless mineral spirits is a purer version of paint thinner. But since you can use odorless mineral spirits as a paint thinner, it's confusing as to what "Paint Thinner" is...
Also, there are different types of solvents. Acetone is different from petroleum distillates. Since it's basically nontoxic and dries extremely fast, it's probably a good rinse solution.
I am probably going to use a petroleum based solvent and then rinse with acetone. For me, I will probably stick with "Klean Strip" line of products since they are cheap, widely available, and looks like high quality. For petroleum based solvents, there is "VM&P Naphtha", "Odorless Mineral Spirits", "Paint Thinner", "Xylene" and "Toluene." I am already having a hard time remember these names...
The differences between them is the boiling point. They have different properties and cleaning "powers". Not sure which is the best for cleaning watch parts since they all can clean grease.
You can also just use a degreaser with water as a first stage then rinse with acetone. Aqueous solvents can be as good as petroleum based ones. Here are some interesting case studies complied by the EPA. Imo, a lot people are using lighter fluid because that's what watchmakers of the past used. Watchmakers used the best they had which was benzene or lighter fluid.
But the world is a different place and there are many solvents available especially for non-hazardous ones.
More choices more confusion...
Edited by dieale2
I tried using water and it had two big issues. First, water melted the shellac. I couldn't believe it and thought it was heat. But I ran the same pallet fork in mineral spirits and it was fine. It could be the detergent and ammonia solution I used, but again I need to confirm it.
Edit: turns out it was the detergent and ammonia I was using. This woodworker dissolved shellac in water using borax which is a common detergent. Since I also added ammonia, it probably made te situation worse. Learn new things everyday...
Edit2:  Another thread. A chemist mentioned using ammonia would dissolve shellac.
Second, sometimes I leaves parts in the cleaner for long periods of time because I forget or need to do something. Turns out mineral spirit and water separate each other. You end up with a pool of water at the bottom and you end up rusting parts because of that.
Acetone dissolves water since they are both polar. Seems like that's a better choice for a rinse if you want to use water based cleaners.
Edited by dieale2
  • 2 months later...
 So I know I’m going to need some kind of cleaning set up, but there’s no way I’m dropping $700 for a proper cleaning machine.   Not when I can get an ultrasonic cleaner off Amazon for fifty bucks.
 So I’m thinking I’ll get a bunch of those screw-top mesh baskets to put all of the watch parts into.   Then I’ll get three jars, one for wash, one for first rince,  and one for final rinse.   After final rince I figure I can put the baskets on some paper towels and dry everything with a blow dryer.
 I figured I could use something as simple as a mason jars.   I’m concerned about putting glass jars in the ultrasonic cleaner, though.   I’m afraid that after a few uses the glass would shatter.   I suppose I could use plastic jars, but I have no idea where to get cheap, clear plastic jars.
 I know there are specific solutions that I’m supposed to use.    Can I get away with just using ammonia & water for the cleaning,  distilled water for the first rince,  and rubbing alcohol for the final rince?
Does anyone else use anything similar  as an inexpensive cleaning station?     Or anything vastly different but still not too expensive?  I figure I can put together the set up above for about hundred and a half,  and I like that better than 700 for a proper cleaning station.
I did purchase a cheap ultrasonic cleaner from a retailer (Lidl) those in the UK will be aware of this shop. However it is crap compared to my half decent one I purchased a few years back. In fact I now only use it now for watch bands once I have pre-cleaned them. The cheap ultrasonic's do not vibrate (sorry don't know thew correct terminology) enough be effective. The better quality machines have up to 40khz of action and more than one transducer. The old story you get's what you pay for. Also size matters ie if you are just going to clean watches then a small tank will be fine but if you are going to clean clocks then you will need a bigger tank. Some say you should not clean clock parts with an ultrasonic but I do with (so far) no issues.
I have experimented with many solutions. I have been using Elma 1:9 for my clock bits. However be aware of the workspace you are working in some solutions are really pungent. I purchased ultrasonic carburettor cleaner and it stunk the house out. Wife was not happy.
    • Got another one today! It took 10 weeks, but finally arrived. Fairly complete but I added the pivot guage. The burnisher and bow came with the tool. The case is a bit rough and the tool pretty dirty, but trying to decide how much I want to restore.
    • OK, so long story short, I'm working my way through Mark's courses using a "Sea-gul ST36" (or ST3600 from some vendors) AKA an ETA 6497 clone. as a practice piece.  I've had it fully appart and cleaned it, and have had it fully back together an "running", but only briefly as my oil hadn't arrived at the time.  In the course of that work, I saw no markings on the movement that would tell me if it was a true Sea-gul or just a clone of their clone of the original ETA movement. Well, fast forward to this weekend, when my oils arrived in my mailbox and I sat down to try my hand at oiling.  Everything was going swimmingly until I got to the shock setting on the top of the balance cock.  I was able to open the lyre spring without issue, but in attempting to swing the open to access the cap jewel and chaton, I apparently accidentally pressed the launch button as I sent the lyre spring into low earth orbit.  Like most things that make into such orbits it came back down at a place not too far from where it started, but of course that also means that it is no longer in the setting. So my task is now to get said spring back into setting.  What I have read so far tells me that I seem to have two options: Another thread here seems to indicate that the spring came out without taking the balance cock apart, therefore it should go back without the need for that procedure.  That seems a bit pie in the sky for me, but the posts in said thread also gave some high level information about how to get the spring back in (putting it at an angle to the channel cut in the cock and canted so that the tabs fit in the slots, followed by some "wiggling" to get it turned around the right direction.)  I've tried this a couple of times, which have lead to more trips to low earth orbit, but with successful recovery of the orbital vehicle after each trip.  This thread also suggests that what I did to cause the initial launch was to push the spring "back" with more pressure on one side than the other, which put it under tension and caused it to deform out the slot either on one side or at the end (where there is apparently no "back stop".) The other option appears to be varying degrees of disassembly of the balance cock.  Some things I've read suggest that the whole shock setting needs to come out, while other threads here suggest that I only need to remove the regulator arm and the arm carrying the balance stud.  After the last trip the spring made, this is seeming like a better option, but I'm super short on details on how to do what needs to be done.  if I am following correctly: I need to loose the balance spring stud screw so the stud is not held in the arm. I need to somehow disengage the balance spring from the regulator (all the regulators I've seen in videos look nothing like what I see on the balance cock I have.)  What I've seen on the interwebs is a couple of "pins" that the spring passes through.  What I see on my assembly is something that looks more like a single pin with a "V" shaped notch cut in the bottom of it.  The spring is secured in that notch with something that I guessed was glue, Posts here suggest that on some of these movements glue is in fact used.  So I'm trying to figure out how to tell, how to soften dissolve it (I'm guessing IPA or acetone) and how to put it back when I'm done (superglue?  UV glue?) With the spring detached from the cock, I've read that the regulator and stud carrier are basically glorified C clamps around the shock setting and that one removes them by slipping a razor blade under one side of each and prizing them up.  I assume that they go back in the reverse manner like another C clamp, but that again is only a guess.  The place I got this information from seemed to leave that bit out. Once I have one or both arms off the shock setting the above mentioned post seemed to indicate that I could just slide the spring back in the slot, though again, I'm interpolating between the lines I read.  The alternative that I've seen demonstrated on high end movements on Youtube is to remove the entire shock setting and to replace the spring from "underneath" rotating the setting so that spring basically falls into place. I'm not anxious to try this method, as I don't have a jeweling tool to put the shock setting back into place.  That not to mention that the professional watch maker who did the demonstration described "fiddly work." So at the end of the day I'm looking for a little guidance on which pathway to follow, or if I've missed something obvious, a new direction to follow.  If this is a repair that just need to wait until my skills improve I'm totally good with that, I can get another of these movements in relatively short order, I just don't want to treat this one as disposable, and I do want to make an honest effort at fixing it and learning from this experience. Thank you in advance for reading my ramblings and for any suggestions that you might have!
    • All the best, family always comes first, and I believe you have made the right call that you mother deserves your full attention. However, when you need a little outside distraction the guys here will always be available for some banter or a heated discussion on lubrication 🤣.
    • Wire for what? if it's steel then only certain types of steel can be hardened ie high carbon steels: "Mild steel doesn't harden very well. It doesn't have enough carbon. Get something like O1, silver steel or if you want to go full watchmaker, then Sandvik 20AP". Source
    • I'm wondering if there's any specific type of wire I should get for hardening? I would assume it doesn't matter as long as the wire doesn't melt before it is at temp.
