The solutions are fine, I am now trying to clean everything with isopropanol and rinse it in acetone. However, I am not sure how to clean without the cleaning machine. My idea is to after soaking parts in isopropanol, clean every part with soft brush, peg everything I can, clean pivots with pithwood, and rinse. However, I am not sure what to do with the hairspring. It is very sensitive and I am afraid to deform it by cleaning it with brush.
As for the balance spring , I would suggest one dip or an alternative degreaser, you shouldn't need much more than that.
Sent from my ONEPLUS A6003 using Tapatalk
If you dip the HS in Acetone for a short period then you need have no fear of there being any old oil left on it. It will be oil free. Acetone is the best de-greaser I know of and is used for strain gauging operations where Any Oil would be anathema to the bonding process !!. I have isoprop but have never used it.
Acetone will dissolve shellac so avoid cleaning pallet forks and balance wheels with this.
I use lighter fluid (zippo/ronsonol) and swirl it around in a little cup while brushing with a cut-down paint brush (stiff artist type). Then inspect and clean with pegwood, especially the pivot holes and gear teeth followed by a second rinse in the lighter fluid.
Nothing beats a cleaning machine but for a hobbyist cleaning by hand is a cost-effective alternative.
Anilv
6 hours ago, anilv said:
. use lighter fluid (zippo/ronsonol) and swirl it around in a little cup while brushing with a cut-down paint brush (stiff artist type). Then inspect and clean with pegwood, especially the pivot holes and gear teeth followed by a second rinse in the lighter fluid.
I recommend against lighter fluid. It is formulated to burn clean and smell good, not to clean parts. If you like to use a petrol solution use refined petroleum ether as mentioned earlier.
Topic merged as it's essentially the same subject.
I cleaned a Tissot 784-2  hairspring 4 times in lighter fluid and still sticks together. Used a brush and cleaned the hairspring under the microscope  with acetone. Let i dry and now it's running good.  There are some hairspring cleaning fluids out there. But many of them use tricloretylene which is no good for the health. So i stick with my method
Lighter fuel is made to burn easy and smell good, not to clean parts. As a direct replacement I recommend petroleum ether which is highly refined. I think I wrote this five times this week only.
But I know that many people clean there movement parts in Zippo or similar.  I use Elma and Iso. But not  for the balance and pallet fork.   Is petroleum ether the same as  clean chemical petroleum.
36 minutes ago, rogart63 said:
(---) Is petroleum ether the same as  clean chemical petroleum.
1
I'd really like to know as well. Not living in an English speaking country I often find it near impossible to translate the English names for various petroleum products into something meaningful in my own language. Google translate isn't much help in this context translating verbatim. And, to make matters worse, most horological suppliers (like CousinsUK) aren't allowed to ship anything flammable to Sweden. How do you get hold of this stuff if you don't live in a large country like USA, England, Germany, France, and so on? There just aren't any local suppliers, at least none that I've been able to find.
It’s more complicated than that.hexanes and pentanes. Short chain chemical composts. Best shortcut is to identify yourself as a restorer, and get the pure products they use and favour. For example, when cleaning oil paint, a mixture of acetone, xilene, hexane and so on is always around..
This is what I got:17f7401dd89b258aef9668c4d09efe94.jpg
The impulse jewel on the balance is held in place by shellac generally (maybe on newer watches they use a synthetic glue) and this can be dissolved by acetone/thinner etc.
In de Carle's  book he mentions drying the balance in a tin of wood shavings. I can see the benefits of this for contaminated hairsprings as the wood shavings will wick away the cleaning fluid as well as the oil.
Anilv
  alcohol ----  isopropyl is what the industry uses,   avaible everywhere.   why use lighter fluid ?  your watch problem  lays in other areas.
  • Confused 1
Cousins poor shipping limitations derives probably from lack of understanding of the actual shipping regulations (which can vary from one service to another) so when in doubt they choose not to ship overseas. For example, if an UK seller can ship practically worldwide, then Cousins could as well. https://www.ebay.co.uk/itm/Petroleum-Ether-80-C-100-C-500ml-Petroleum-Spirit-Shipped-Same-Day/142061406816
Note, the above is just an example, because the cost is prohibitive anyway. And if you read the description you'll find the other most common English names of what, in the end, is basically spark engine fuel.
Also note, all these petrol derivatives do not dissolve shellac.
Please read my post properly @vinn3 How said i have problems?  But if you read on different forums you see that others use lighter fluid or naptha or whatever it's called to clean the movements.  But this an everlasting question on many forums.
I think that's because it's recommended in old books like DeCarle which is then blindly followed. But since then the world has evolved and many more products have become easily available.
  in de Carle first book there were not many choices of a solvent at that time,  for dealing a with glue used (shellac). you are quite right there.   it is a chemists' problem.       so,   if you take the pallet fork out;   what is the best solvent for watch cleaning?    I have used isopropyl for years for its cleaning ability .  vin
If you look at the commercial cleaning fluids such as L&H watch cleaning solution.
http://www.lrultrasonics.com/msds/111 Ultrasonic Watch Cleaning Solution.pdf
You will see one of the main ingredients is Naptha, or as it is called in Australia Shellite (Or commonly called lighter fluid). If it is called something else in other countries on its MSDS (or SDS) it will also be identified by its CAS number 64742-89-8
A CAS Registry Number, also referred to as CASRN or CAS Number, is a unique numerical identifier assigned by the Chemical Abstracts Service (CAS) to every chemical substance described in the open scientific literature.
So if you want to find a chemical that is called one name in the USA or UK and you don't know what it is called locally find an MSDS and look up the CAS number this will help you identify it.
For those interested here is a list of the chemicals used in some of the commercial cleaner, as you can see each has a set purpose and it is the combination of all these chemicals that do the job, this is why Napha, or IPA alone wont do as a good a job, but is still better than nothing if its all you have.
The percentage used of each chemical gets lower as you go down the list.
Mineral Turps - degreaser of waxes and polish
Shelite (Naptha) - another degreaser
Olecic acid - emulsifying agent
iso propyl alcohol - solvent and drying agent
2 - propoxyethanol - solvent highly active
monoethanolamine - corrosion inhibitor
CAS 64742-89-8 is Petroleum Ether as I've been saying here since a couple of years now.
https://www.chemicalbook.com/ProductChemicalPropertiesCB5248177_EN.htm
Lighter fluid can be very similar but I don't think it's exactly the same. It's made to burn, not to clean
 CAS 64742-89-8 is also called Naptha. Commonly available in the U.S. as Varnish Makers & Painters (VM&P) Naptha. It's a petroleum distillate, i.e. distilled from crude oil. Someone familiar with distillation might call it a "cut",  or collection at a specific point in the column, that gives it certain properties.
It works, I used to use it, but I've since switched to Zenith cleaning and rinsing fluids, and the difference is quite dramatic. I won't be going back.
I always use Naphtha with a U/S cleaner and also a brush. For the HS and balance to get it 100% degreased I use Acetone. This old method has never let me down !!.
I partly agree with you. Buying a tin of lighter fluid may be chemically the same, but could have much higher levels of impurities in it, so may not evaporate as cleanly. Also from what I've seen in Australia you can buy 1L of Shelite (Naptha) for the same price as two 100ml cans of lighter fluid.
What is a safe to breath and  biodegradable cleaning product I can use in the u/s cleaner. (Benzene is carcinogenic).
l’ll be using a mesh basket.
Also, can someone provide a link for the tiny glass jars that can fit in a jewelry u/s cleaner?
Edited by mlfloyd1
Additional text
Don’t know about state side but I’ve got my collection of jars from having tea and toast for breakfast, mainly in Starbucks. The little jam pots are just right to get a section in such as the keyless, although could do with a couple that are slightly bigger as some main plates won’t quite fit in them which is frustrating.
I'm not sure that there is an effective cleaner that meets your requirements.
Best to not breath the fumes, no matter what it is. Check local regulations as to what can and cannot be disposed of through the sewer. In many places, cleaners and degreasers have to be treated as hazardous waste, which may mean saving the used fluids and dropping them off at a collection point.
A great "fume hood" is the exhaust fan found over many stoves and ovens,  if you're lucky enough to have such a thing. Otherwise, an open window and a fan might do in a pinch.
The jars that I use originally had Newman's Own Salsa in them. Just watch the lids, some cleaners can dissolve the material that's in the cap that's used as a seal.
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
