Hello,
another newbie question, I know. So far, I cleaned all of the watch movement parts using the ordinary lighter fluid. My system was as follows: put all of the watch movement parts in small jars with lighter fluid, leave them for about 10 minutes (except pallet fork and balance, I took them after few minutes), clean them with a soft brush, peg the pinholes, rinse the parts again in clean lighter fluid in one bigger jar, and leave them on sheet of paper to dry.
Now, I am afraid that the lighter fluid (basically naptha) would leave some residue.
Any ideas on improving this? What cleaning solutions would you recommend for rinsing the parts, and especially for cleaning balance and pallet on budget? Isopropanol maybe, although I heard it could do harm to shellac.
On 10/13/2015 at 8:03 AM, DJT2 said:
Hi guys, I've been absent of late due to decorating to keep the wife happy. But I'd like to discuss a conversation I had with a friend who is the technical manager for a leading Swiss watch manufacturer. I asked him what he felt was the best degreaser to buy at present. He said" without question & nothing can compare, isopropanol which is available from the chemist. I was surprised to hear that they also use it in the final rinse pot during cleaning". He said you can't leave the lid off as it evaporates. He said it's ideal for the last rinse because of this fact.
Has anybody else used this product. I've just order 5ltr off amazon for £15,so pretty cheap.
Well,  In my opinion that info is not quite correct.. The best de-greaser and old oil killer by far is ACETONE !. Isopropanol is one type of  alcohol and has it`s uses no doubt. I have an unopend can here. I am a Jobber Fixer (not a qualified watchmaker) and I am not in the league of you modern chaps. I use an ultrasonic bath (40KHz) and Fast Naphtha. The balance and scape are cleaned with Acetone then rinsed with Naphtha and I brush the components as required. Do NOT use acetone on any plastic`s. Just my way of doing things and it works very well for me.
18 minutes ago, bojan1990 said:
Is it advisable to clean hairspring and pallet fork with benzene or acetone and then rinse it quickly in isopropanol?
As covered many times already, benzene is never used. Refined "naphta" (gasoline, benzine) takes different names according to the country. I recommend against lighter fluid as it's mean to make a flame, not clean part, hence is not refined enough.
Now, since refined benzine leaves no residue, no rinsing is really necessary. But different people do differently.
Another thing that you will read is that IPA dissolves shellac, however not quickly, and not all of them.
1 minute ago, bojan1990 said:
I wanted to say "benzine" aka lighter fluid. What is alternative, acetone maybe? Or should everything be cleaned with IPA?
It's not the same, you should get refined benzine, for the reason explained above. That is the traditional product to clean watch parts, IPA was invented much later and for different purposes. Personally I use either and both work fine.
6 minutes ago, bojan1990 said:
Since it is easier for me to get the IPA, I will try cleaning with it. Do you leave parts for some time in the solution, clean and then rinse?
You can get refined benzine on Ebay. Leave parts few minutes into whatever solution, then let dry under a dust cover. For tiny parts like it's a good idea to use a small mesh basket.
To dissolve oil, grease, and dirt I use a liquid named "Gripen Kemiskt ren bensin". That's Swedish and translates to "Chemically pure gasoline" by Google translate ("Gripen" is the brand). I wonder if a better translation would be "refined benzine"? What do you think? The back of the bottle says (again Google translate): Naphtha petroleum hydrotreated lightly. When I try with "refined benzine", Google translate recommends I visit the nearest gas station, and I don't think that's right?
I buy the stuff at my local grocery store and it's about a quarter of the cost of Zippo lighter fluid. That is, I pay approx $2 for 125ml. I'm sure there are bigger and less expensive bottles or alternatives but I haven't looked into it. The front of the bottle reads: "Efficiently removes spots of oil, grease, and glue", and that seems to be what it does!
For my final rinse, I always use IPA, to remove any possible "cleaning fluid" (whatever I've used) residue. I know from experience that the shellac or resin doesn't go well with IPA, so I'm very careful to rinse the balance and pallet fork very quickly (max 30 sec.).
Anyway, for any parts big enough I definitely get the best results using warm water, detergent, and a soft toothbrush. The jewel pivot holes I peg out, and if necessary also treat with the chemically pure gasoline.
This post by "clockman" was the best info about cleaning I could find when I was new to this. I still think it's good!
Edited by VWatchie
Also a Swedish resident, I use the ”Gripen” benzine mentioned by VWatchie. And btw, the Gripen benzine works perfect as lighter fuel in my Zippo hand warmer I use a lot during winter ski tours, at the fraction of the cost for the original Zippo stuff.
I use two small licqeur glasses and my hobbyist u/s machine with a squeeze of regular dish wash liquid in hot tap water. If I feel ambitious (and can stand the fumes) I add a splash of ammonia.
The parts (in the natural group order) goes into the first benzine container for a few min’s and then into the u/s.
After that back into the first benzine glass again with the main purpose to push out any remaining water from hidden places in the parts. The water separating property of the benzine is a cool one!
Then over for a final rinse in the 2nd benzine glass and out to dry on a regular printer paper.
Lately I have tried to re-use the benzine by pouring off the top section (the water is heavier and stays low) but noted I get some staining, probably from dissolved oils and grease so I will stop that and use fresh stuff every time.
If I note any remaining stains on the jewels, I remove these with a wooden tooth pick.
The procedure usually takes me a 1/2 hour for a regular manual movement, which works for an amateur and hobbyist, I guess.
/Bsoderling
I am sure that someone can give you correct advice. I use an U/S cleaner with Naphtha. I clean the balance and scape with Acetone, then rinse with Naphtha and allow to dry naturally. I do not use Isopropanol. This method works very well for me. Do not get Acetone anywhere near plastic`s and you can buy 5 litres of med or fast Naphtha from you local auto paint shop at around £12. They call it Panel Wipe !!.
I read not to use lighter fuel, but a good replacement is from the Go outdoors camping store, but I can't remember the name, it's a lot cheaper than lighter fuel, anyone???
Coleman fuel. Try Panel Wipe from your auto paint shop. Pure Naphtha, as pure as you will get anywhere. £12 for 5L. It is an excellent watch cleaner. Cheap enough to clean and wash components properly at low cost. Fine for U/S.
You should go for quality not price. Anything that is made to burn is not purified enough for lab or cleaning purproses. https://www.ebay.it/itm/Petroleum-Ether-80-C-100-C-500ml-Petroleum-Spirit-Shipped-Same-Day/142061406816
10 minutes ago, ecodec said:
Fine for U/S.
Using (highly) combustible liquids in an U/S cleaner is not recommended for obvious reason, as written on the device instructions as well. The heating from the process is significant. You can do that anyway one million times and be fine, but I prefer to use only soapy water in the cleaner.
Hi,
I find this test and conclusions a bit strange...
The residue seen on the glass is what’s left after the solvent has evaporated i.e. It’s an indication of the level of impurities in the solvent, not a property of the solvent in itself (that’s not there anymore)
As such this test can be used to determine if your solvent (benzine, alcohol, acethone ...) is as clean as you want it to be.
But to determine if your solvent as such is good or bad, I see no guidance here.
On 7/22/2018 at 5:49 AM, bsoderling said:
Hi,
It's a very useful test for final stage rinsing. A popular cheap way to clean is to use lighter fluid and then rinse with %99 IPA to get rid of the film that it usually leaves behind.
So you use the test (solvent on glass sheet) to ensure the IPA is clean (= no residue ) whereas you don’t expect that from the lighter fluid that is primarily intended for burning and can be contaminated ?
That makes a lot of sense to me and I will try that next time with the benzine I use for cleaning and rinsing.
I soak the parts in Naphtha for a period. Then clean with very little heat at all from the U/S cleaner.  For the balance components and escapement I use Acetone then a wash in clean Naphtha. Sometimes for stubborn staining I use a brush.  This method has never failed me.
1
Please remember to let us know the result. Thanks!
Hello,
is there any kind of guide how to clean watch movement by hand? I found something like that in Practical Watch Repairing book, but I am wondering if there is something on Internet as well. I know that a lot of members use an ultrasonic machine for cleaning, but nevertheless I want to learn proper hand cleaning technique, especially when it comes to the hairspring (as very sensitive part of the movement).
Thanks.
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
