Movement identification
Thanks very much!
I think the hook may be way past being able to be dressed by filing but I'll have a look.
The annealing process might be an obstacle to me adding a pin, but we'll see.
I appreciate your help, thanks.
Edited by Bonzer
I finally managed to remove the cannon pinion. I soaked in oil for a day but that didn't work so then I soaked it in WD40 and that did the trick. It appears that the steel shaft had some rust on it which must be why it didn't come off easily.
On different note, do you think the hook on this barrel arbor is retrievable? To me, it doesn't look as bad as I first thought.
1 hour ago, oldhippy said:
Have you tried the spring on it if so what does it look like and will it hold. You don't want to start fiddling with it if it will hold.  I must say looking at it under magnification it doesn't look good.
It does have a really peculiar look like it was very very poorly made perhaps. The thing to do is to put the spring back in try it and see if it's going to work at all before you try to file or do anything with it. We might be surprised it actually works or maybe that just putting a proper edge on the hook might work if you're lucky.
Well, it didn't hold so I tried filing the end of the 'hook' with a triangular file. It seems it might have worked although I need to test it properly in the movement or with a pin vice.
I will order a new mainspring. The existing one is 1.4 x 0.15 x 380 but I can only find a replacement that is 400mm long. Would this matter very much? The barrel is 12.3mm in diameter.
7 minutes ago, Bonzer said:
400mm long.
Providing the other dimensions are correct that extra Length will not be the end of the world.  The most critical is the width because that determines whether it's even to fit in the barrel or not. The thickness is how strong the spring is this becomes interesting because the original if it was blued steel versus the modern the modern will be stronger for the same thickness supposedly in another discussion group somebody told me as totally wrong on that one but seems to whatever one thinks. Then the link could be shorter or longer it would affect the running time of the gets dramatically too long Or two short but it have to be quite a bit.
Back to one of the original reasons for this thread - the need for a cannon pinion to fit this watch:
I obtained a movement that was very similar but not similar enough (see warning in earlier post by oldhippy 'they look the same but there is always something wrong')!
The cannon pinion in this replacement movement is slightly shorter but the pinion meshes nicely with the wheels and the existing hour wheel will still work nicely.
However, the diameter of the centre hole is slightly smaller than it should be to fit on the existing pinion shaft. Now, I need to use the existing shaft because the minute hand needs to fit properly. Is it viable to ream the hole in the new pinion so it fits the old shaft?
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
