Hardening a handcrafted pivot
I am fixing my Seiko Yatch. It got a mode staff pivot broken.
So I made a new one out of All Purpose Watch Repair Wire Steel from esselinger. I also have the blue steel wires as well but decided not to use it.
Have I made the wrong decision? Should have done with blue steel?
Is there a way to harden the one I did? Should I try heating it with leather charcoal to inject carbon and then temper? Will that work?
Edited by gkmaia
38 minutes ago, Elton said:
Apply heat for a while & dip in oil will harden it. Another option is to place the metal on a piece of brass & apply heat slowly & watch for it to turn blue.
Great Thanks!! will do that.
I doubt that they would sell an unhardenable steel, so no need to "inject carbon".
If you want to harden steel, the typical alloys that a watchmaker might use would be oil hardenable or water hardenable. At watch size parts either will harden in oil just fine, so don't fret about knowing which type you may have. It needs to be heated to its critical temperature, which for practical purposes isn't a number but a color- you want to get it a dull orange color, then immediately drop into oil (about 0.5 liter is good). It can be pretty much any oil, but thinner is better than thicker. Now the steel is completely hard. To test if it did in fact harden you can try to cut it with a fine file (like a 5 or 6 cut). The file should slide and not bite. Obviously try this on a piece of your steel that hasn't been made into a part yet! Once it's hard, you need to clean off the scale and black color, then heat it in a pan of brass filings or fine sand, normally over an alcohol lamp, and bring it up to a blue color. Now it's tempered. If left in the full hard state it will be too fragile, tempering reduces the hardness, while increasing toughness.
Once it's blue you can clean it up in your lathe, the blue comes right off with fine grinding or polishing paste.
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
