Another idiot.
oldhippy
I couldn't watch it all, it was too painful.
Shook the watch out of it's case.
Used to flat bladed screwdrivers to remove the hands. (But atleast he protected the dial....)
Used a magnetic screwdriver to unscrew the screws.
I have chopsticks that are finer than the tweezers he was using.
But I did like his enthusiasm.
Exactly my point. There are plenty of idiots out there on YouTube. Whether it's watch repair, cooking, health advice or the worst medical advice. You always have to check the source and check out several similar videos to see if they are all saying the same thing. And always use common sense.
BTW did you guys watch BBC Foods video on egg fried rice? It's hilarious.
  • 4 weeks later...
Well It might have been an old cheapie but it deserved more respect, how he has still got all his fingers and toes Is beyond me.  His repairing worn holes is a disgrace. However cheap the clock its no excuse to close them up like that.  Enough grime on the hands to stop a dozen clocks
"I know this arbor comes out of the mainspring. I just know it does. Where are my bigger pliers?"
" I know what I'll do. I'll just hammer the mainspring into the barrel."
How much stress did he put that central wheel under by forcing the two spring barrels into place?
Ok. Speeding things up makes things look a bit worse, but still. I wouldn't have even put things under that much pressure when I was reassembling centrifugal pumps or ball and rod mill double helical gearboxes. If I had, I would have been dealing with a really angry tradesman.
Oh and to anyone thinking this, 'Pliers are ok for undoing and tightening nuts.' No. No they aren't.
Note to self: Do not watch anymore videos by Mr.Electricity.
About me: Hi. I'm a diesel mechanic who can't afford soap. I also deal in clock repair. Well, I'm calling it repair.
Edited by Michael1962
But you have to admit that this guy knows his way around a clock. It's definitely not his first rodeo.
This is typical of "antique restoration" shops in South East Asia. If you look at his other videos, he repairs stuff other than clocks too. When I first started working, my clinic was situated in an area with many such shops. I spent many hours watching "junk" transformed into "antiques".
I'm just wondering which part of the world he's in. His written English in his YouTube channel is too good to be China or Hong Kong. I'm suspecting he's from Singapore or Malaysia.
6 hours ago, Marty said:
Hi all
Would the Ollie Baker Style mainspring winder be beefy enough to remove / fit fusee mainsprings.
How long is a piece of string?
By that I mean yes if you are talking about regular fusee clocks, no if you are talking about giant fusee clocks that used to be in big train stations.
A few months back I was shown a fusee clock under repair that used to be at Fremantle train station in Western Australia.
That one had a barrel that was over 10cm high.
To remove that mainspring they essentially had to make up tools so they could turn their lathe into a large hand operated mainspring winder.
I had something like this it would handle all that came into my workshop and I had many fusee clocks with very large mainsprings. You will need a good bench vice to hold it in.
I think clockboy has the Ollie Baker one, ask him I'm sure he will help you and tell you all you need to know.
If you look at any of the clock material suppliers, check out fusee springs and look at the measurements that will give you the info. It should be possible to have a spring made for something that is out of the range, mind you it will be expensive.
Have you ever seen one of those springs for the old wind up gramaphones? they are massive.
2 hours ago, clockboy said:
I have indeed. There are a few vids on YouTube showing how they work. One issue is my one did not come with the let down winders.
That is pretty common.
I bought mine without the let down winders and bought them separately off ebay as it saved me about $50 doing it that way.
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
