Rotary mp00712 running too fast
Hello!
I have a Rotary mp00712 skeleton pocket watch. It was bought for me as a gift several years ago. I love it but it runs a bit fast (several minutes gained per day). My other pocket watch has a very clear lever in the back with a +/- adjustment, but I havent been able to find an equivalent on the Rotary one.
I have managed to unclip the glass (front and back) to see if there was an adjustment that I couldn't see, without success. It was hard work getting the glass to clip back on - any technique I should know about? There are plenty of pictures online if you google "rotary mp00712". Mine is a gold one but I don't expect that matters for this.
I'd be happy to take any specific photos if it helps. I love the watch and wind it every day, it would be nice if it would tell the time reliably too!
Thanks,
Stewart
While that is a true statement that there are plenty of pictures online they are worthless for what we need. We need a picture centered above the balance wheel on the back side. Then another decent picture of just the entire movement on the back side.
Update: I have made a few adjustments over the last couple of days, resulting in the image as below. It turns out that both of the little silver arms move, I'm not sure if it matters where they are positioned, or whether it's just their position relative to each other, but it seems to keep fairly good time now. Running ever-so-slightly slow this morning so I know the range and need to make my tweaks smaller!
Thanks so much for your help.
The arm where the end of hairspring is adjusts the center of oscillation, as explained in this video by our Host Mark Lovick. For an accurate setting of that, as well of the rate, a timegrapher is needed.
That looks like a "Tongji" or Chinese Standard movement.
https://en.wikipedia.org/wiki/Chinese_standard_movement
I suspect the coils on the balance are touching while it is running, or there is oil on the coils, or the movement simply needs servicing.
Can you post a current picture of the balance at rest. i.e. after you adjusted it.
The good news is that the movement is very easy to find and to get spares for. The quality of the movement is variable though. Some versions are actually quite well built, and some are, well, not so good to put it politely.
Rotary used to only use Swiss movements, but their more recent offerings use movements from China, Japan and Switzerland.
I have a couple of watches with skeletonized Chinese standard movements and they are reasonable time keepers once cleaned and oiled, so you should be able to get it working acceptably well.
Edited by AndyHull
You could use tg-timer from here -> https://tg.ciovil.li/
There are also a couple of phone apps that can do watch timing, but I haven't tried any of them.
I do however use tg-timer on my laptop, which is almost as good as a "proper" watch timegrapher.
Unfortunately, as most readers here know well, there is little chances of getting realiable results from a PC or mobile app without using a proper microphone. That should be told t9 beginners in order not to set wrong expectations. The thread below is about that exactly.
I think this is getting a bit beyond my capability (and aspirations)!
I'll wait for the watch to run down and take another picture as requested, but I'm minded to carry on with the tiny tweaks until I get reasonable performance and if I don't manage it I'll look up somebody local to service it once things start opening up again.
The internet is a wonderful place for help with anything and everything, I'm grateful for your advice. If any of you experts happen to live in the East Devon area and would do a service that might be of interest!
Quote
I agree completely.
I personally get away with using the built in microphone on my laptop or the one in my headset, however your mileage may vary.
You also need a very quiet environment, otherwise you will pick up spurious noise from your surroundings. This is why a good quality microphone in a sound proofed container is a very good idea.
This is one of the advantages of a "proper" time grapher. It includes the microphone and a clamp that lets you time the watch in different positions. They are probably also a little better at filtering out noise from their environment.
For hobby use though tg-timer has served me well.
Edited by AndyHull
If you are careful, and take your time, there is a pretty good chance you will get it working.
By the way, "The basic specification of the Standard wristwatch caliber is a minimum of 17 jewels, 21,600 bph (beats per hour) escapement, a minimum 40-hour power reserve and an average rate within +/-30 seconds per day."
The ones I have perform better than this, but an average rate within +/-30 seconds per day is the figure to shoot for.
Edited by AndyHull
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
