Update on Elgin
 Just an update on the Elgin, What a bag of worms, balance cock has been punched, the cock seat has been punched  the lower balance jewel endcap setting is missing, upper jewel endcap end stone is loose, balance staff upper pivot tip is broken,  So far Its been cleaned and I have turned a solid brass end cap for the lower setting, Fitted a new staff to the balance. Now got to sort out the upper jewel end cap and adjust the end shake. Then the brown stuff hit the fan  No1 Lathe broke its belt,  so switched to No2  It did the same, then the bench light head broke  so I have had to stop for a while. An interesting day all told.
A problem with American pocket watches and not unique to American is that their old. Typically at least 100 years old this means that for the last hundred years they've either had a nice life or they been serviced a lot by people who may or may not of actually known what a watch was. This means that you will get challenges even on a watch that appears to be in beautiful condition and appears to only need cleaning there will probably be a challenge or two.
Or in other words welcome to my world. In the shop where I work I handle all the vintage pocket just and continuously they want to know when the watch is going to be done and the answer it's done when it's done doesn't always come across properly. Like in your case even when you fix all of those problems you may have weird timekeeping issues which you won't know about until the watch is running.
Exactly so John, If you are working day after day on these you must be challenged on a daily basis by both the watch and the ,client who only sees it as “it’s just a watch” with no regard to what is inside the case.I always read your posts with interest, you must be a patient man.   Regards
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
