Clocks and watch stuff
Michael1962
I have found out that both clocks are 31 day Jupiter clocks from Korea. Both cases are chipped or the carvings are broken.
I am not sure about all the parts in the three plastic trays. Could be anything and I have no way at the moment of looking at things and knowing what movements they are from.
Sorry. New to this. I was on the page where the stuff was showing, but it looks like the link takes you to the top of the group. If you scroll down in Geelong Online Garage Sales, you might see it. I will also try to download the pictures and post them.
I asked whether any of the watch or clock parts were identified or marked etc and never got an answer. Didn't go any further with it all. I think it was $80 for the lot which maybe got two clocks which could have been used as learning and practice and maybe some watches for everyday use, but I am pretty sure that just about everything in the plastic containers could pretty safely be classified as junk.
Sorry I missed this. Those clocks wouldn't be good to start to learn on very poor modern movements. I can tell because of the way the arrows are pointing, you wind these up the other way to who you would normally wind a clock. You are right about the plastic boxes. As for the watches I don't think you have missed anything. You have done well in saving your money.
@oldhippy The question that I referred to in my previous post was to the seller. That is who did not reply. I wasn't about to just fork out money without having any real idea as to what I might be getting.
I will just have to keep working on the clocks I have for now and keep looking.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
