The machine arrived today. Overall it is in decent condition for a machine from the 1940's. The glass canisters are in very good shape, without cracks or anything of that order. There are a couple items that need attention before I can put this machine to use.
1. The basket holder is in terrible shape. It is badly corroded and will need to source a new one which may not be easy to find. This is by far my biggest concern.
2. The reverse switch is just ugly looking. It is a momentary push-button switch which I would guess is illegal to use under current standards. I think a modern three position switch will work better.
3. The rheostat does not look too bad, but I will feel better once I get it replaced.
Most of the wiring was replaced with a high quality (not really) extension cord and electrical tape. That needs to be fixed.
Refinishing this will be fairly easy. The paint comes off just by rubbing my nails against the machine. I think a nice acetone bath and the paint will be completely off, similar to what SSTEEL did with his machine.
The heating element works as designed. It even has the correct bulb installed.
Taking everything into consideration, this was not a bad deal at all. Here are some pictures.
What a fantastic and professional re-wiring. Speechless.
The basket holder is pretty much done. I don’t know if this is a single assembly, or if corrosion joined the shaft with the fan. This may be a bit more difficult to repair, but I am staying positive.
The heating element does not look too bad. Notice the white insulation beginning to show signs of burn? That wiring needs to be fixed.
The rheostat is not too bad. There is rust on the terminals, but it seems to work. I had the machine running for a few minutes and I still have all my fingers.
This is the most interesting part:
I am assuming the star-shaped piece is to keep sediment at the bottom of the jar while the machine is running. I just cannot figure out what the other piece is or what it is for. I am guessing this belongs to another model. Any ideas?
Not too bad for a machine this old. The motor is in very good shape and runs strong. This will make for a nice project and I am hoping I can put it to use.
Today I've been kept busy around the house, but took a couple of minutes to play with my new machine. I was able to remove the part that holds the basket from the motor shaft. I was surprised that after almost 70 years, this was so easy to remove.
I am contemplating the idea of repairing this, if I cannot source another one. I am thinking about using a two part epoxy to coat the entire part then sanding it smooth. My one concern is how will epoxy react with the cleaning solution.
I noticed this yesterday. At the botton of the motor housing there is a rod with a hole on the top side. I am guessing this is for oil to keep the motor shaft lubricated right where it comes out of its housing.
As I continue to handle the machine, the paint continues to come of. It is actually kind of funny.
I've been working on a circuit to automate the forward and reverse motor movement of the L&R machine. Last week I noticed that the motor hesitated to turn on lower speeds. After some testing, I determined that the bearings were bad and needed to be replaced. Ordered a set of bearings from Amazon and today I started working on replacing them. I was surprised on how relatively easy they were removed. As I was getting ready to assemble the motor, I took a closer look at the motor casing, especially the upper half. And this is what I found...
I am glad I found this before I went further in reassembling this motor. I will be rewiring the entire machine in the next few days. I am guessing the only reason this motor did not go up in flames is because the bare metal is not touching the clamp.
By time I am done with this machine it will be practically new.
  • 2 months later...
It looks in good nick. The first jar is where you put the cleaning solution I think you will find the jars are marked with a level so as to not to over fill. The next two is for rinse. The large black nob is for speed, you have forward and reverse switch but I can't see a on switch for the heater. When you have cleaned the parts slow it down loosen it and raise the basket so its out of the fluid but still in the jar and spin it off, then move it to the first rinse, repeat for next rinse, then the heater, make sure the heater is turned on before you need to use it after its been in the heater you will need to spin it to cool it down. The basket will have little sections for wheels and small parts, the plates can go in the large part of the basket, make sure the basket is a good fit and not slack. I used L & R cleaner and rinse but to be fair I'm not sure if there is anything better these days because I retired many years ago.
Thanks oldhippy I he not received the machine yet , so I am not sure where the heater is turned on. But the seller is including the instructions manual and electrical diagram with the machine also an extra heat lamp just for good measure . he specializes in restoring and refurbishing old L&R machines so I am hopping it will be a good cleaner.
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
