Info on Key Winding Pocket Watch??
The main spring is snapped! ?
Not sure how to go about finding a replacement, is by length? Any idea how to measure the length of the coil?
The inside diameter of the barrel is 16.9mm, the spring is 2.5mm wide and 0.2mm thick.
Obviously, being a fusee it has no return like modern springs, its just a straight coil with a hole on either end.
48 minutes ago, oldhippy said:
You measure the diameter of the barrel and it's inside height.
Can’t Find one on Cousins, any other good sources for replacement springs?
The specs are:
Barrel outside diameter - 18.3mm
Barrel inside diameter - 16.9mm
Barrel outside height - 3.8mm
Spring Width - 2.5mm
Spring Thickness - 0.2mm
Spring Length - 410mm
1 hour ago, oldhippy said:
Have a look at the Resources at the top of the page. As it’s very old you might have to get the nearest to your measurements. You could try ebay.
1 minute ago, nickelsilver said:
Cousins has it. Search mainspring by size, 2.50 height 0.20 thickness and you will get everything that matches that. There's one for a 17mm diameter barrel which is perfect for you, 50 in stock.
Thank you.
I decided to strip the fusee before looking for a spring and may have met disaster.... after opening the fusee it looks as though one of the tiny clicks has broken off its tip. I can’t imagine this will be easilly replaced!
2 hours ago, Robbie010 said:
Found a job lot of fusee’s on ebay for £15. Took a punt, fingers crossed I can either steal a click from one or simply replace the whole fusee if one matches. ??
There are a few bad teeth on that wheel, that is due to the spring breaking. Lucky the chain didn't snap. You might be lucky with ebay.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from .
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
