Info on Key Winding Pocket Watch??
I picked this up from a friend today so I'm trying to gather some info on it before moving forward.
It is a silver cased pocket watch, key winding (I dont have the key), looks like a chester hallmark and the date letter is either a capitol i (I) or a lower case l (L).
Going off the date letter and the cartouche, I think it is dated to 1892?
Can anyone shed any light on the movement or maker?
Also, how do I remove the movement from the case???
Edited by Robbie010
You will need to remove the bezel. In the photo where the red arrow is pointing is a case screw you need to turn that and the movement will come out from the front. It's an English full plate movement. I can't quite see the makers name on the back plate. If you can tell me what it is I can look him up in my books and give you a better date.
Thank you, I’ll take a look.
The movement is signed J. Shaw & Sons Bolton.
This thing dies not want to come out of the case..... I’ve ended stripping most of the movement down while still in the case to get a better look at how its held in and I’m still uncertain how to safely remove the dian and main plate.
There seems to be some kind of latch and screw where you pointed to.....??
Can you show me the whole case. The name J. Shaw & Sons Bolton aren't recorded in Watch & Clockmakers of the World Vol 1 or 2. I think it was a jewellers shop by that name and they had there name stamped on the movements and dials. The movements would be mass produced.
Done it! ?
There was a tiny metal pin opposite the hinge, just inside the watch bezel. It was quite worn but with a little persuasion I managed to get purchase on it with the pliers and pull it out then the movement swung open.
Looking at the case it looks as if its a stop watch movement. The part that I have ringed in red looks like the stop for the hack that is in the other photo blue circle. So I suggest unscrewing the screw that has the green circle around it. This case and movement sure is a funny set up.
The button you circled in red is just case feature that allows you to get purchase with your nail to open the hinged case back & bezel.
The thing circled in blue appears to be there to simply rub against the underside of balance wheel..... maybe to add some friction??? ?
It’s certainly a strange one.
Next question.... any idea how the setting wheel is removed?
Silly me I had forgotten about this. Where the hing is sometimes that holds the movement in the case so by removing the pin in the hing the movement might be removed. Your other question I will help tomorrow. It's bed time for me.
This watch is starting to reveal its secrets...
Looking closer at the button on the side of the case, it should actually move side to side (or up & down depending on how you look at it), which, through a basic mechanism moves a strange fork behind the watch face that doesn’t seem to interact with anything. However, at the same time, it also moves the small balance wheel tickler back & forth..... any ideas?
I’m beginning to think this may be a re-purposed watch maybe?
Apologies, I realise I am asking multipe questions here......
This is an English Fusee Pocket watch. The chain is still attached to the fusse, it should unhook.  I must ask this have you ever repaired one of these and do you have any experience with pocket watch or watch repairs. This type can be very complicated to work on.
Thanks. This will be my first experience with a pocket watch in general so I’m learning as I go. Obviously, my first task to tear it down isn’t going great...... ?
Oh boy this is going to very hard for you. First I want you to take photos of every part you have of that movement the closer the photo of detail the better this must include pivots and teeth of the wheels and the balance. When you have done that let me know. Another thing is the chain complete it should have a hook on each end they should be slightly different.
Oooh... exciting! ?
This is where I am at so far.
I have not yet looked at stripping down the main barrel or the fusee wheel.
The centre second wheel passes through a centre jewel and has a brass collar stopping it from being removed. Should I leave this well alone and clean in-situ or attempt to remove the wheel?
A couple notes. The wire or pin which you said rubs against the balance is for "hacking" or stopping the watch temporarily to make sure the seconds hand is exact.
Also, by the 1890s all American watches were stem wind. I know this is English, but I'd guess it to be earlier.
You will need to check all the pivots and teeth of the movement as the photo is so far away I can't possibly see the detail. If you don't have the proper tools leave that coller alone. Don't forget to check the balance staff and pallets.
Yes this is a late fusee movement as the early ones had a verge escapement.
Did one similar some time ago.
The Pocket Watch by Christopher Barrow is an excellent book covering this type of movement.  Some on the bay at £14ish
Hardest part is trying to get all the pivots in the top plate aligned when assembling. Mine had posts with tapered pins to hold the top plate to the main plate.
Did this twice, taking ages, without mishap. Then decided to strip and take proper pics and, yes, I broke a pivot on the pin lever.  Still not got round to getting it  re-pivoted (not got facilities to do myself).
Edited by canthus
It only has one barrel the other part that is cone shaped is the fusee. You need to clean both of these. You will need to remove the mainspring and make sure it is in good condition and remember which way round it is in the barrel. Have you checked all the wheel holes holes making sure there is no wear, this applies to the barrel and fusee. Also the pallet holes. pluss the pallet stones.  Make sure the jewels for the balance staff are clean and not damaged, pluss the balance staff.
    • Hi. Breaks like this can br fixed with conductive paint like the paint used to repair a car  rear screen heater. I have used it successfully, you don’t need much and unlike solder there is no heat 6020A-1.pdf
    • the problem with vintage watches and yes quartz watches can be vintage is availability of parts will be a problem. I have a link below where we can cross reference the coil and  I was hoping for more. Another problem for vintage parts are everyone on the group gets used to ordering from online. Conceivably the physical material houses that still exist out there might have the part and you'd have to reach out to them and see if anyone has one. this is because they don't list every single part that they have online with the exception of cousins where everything they do is online work just doesn't exist but the other material houses can have stuff not listed. Otherwise just set up a search on eBay and sooner or later it will possibly show up if you're lucky.   http://cgi.julesborel.com/cgi-bin/matcgi2?ref=SEK_6020A
    • Hi welcome to the forum.    Enjoy
    • the bestfit book refers to Revue as wittnauer and the fingerprint we have this.
    • Maybe a little off-topic, but it still amazes me that most people (and myself before I got into this hobby) don't realise that the movement of their watch was (in most cases) not made by the name on the dial of the watch. This is especially true of many 'fashion' watches which use the cheapest of cheap movements ($4 each) which are completely out of proportion to the overall cost of the watch ($++100s). Usually the actual manufacturer is stamped somewhere inconspicuous on the movement, usually around the balance, and this is what you need to find so you can locate spare parts or servicing manuals etc. This is like buying a top of the line Rolls Royce Phantom and learning it has a BMW engine..... oh wait a minute, it does! (6.75-liter, 460-horsepower BMW V12 engine - reference)
