Issue with Bulova 23
Hello all,
was working on servicing this Bulova 23 I got at a pawn shop.  It was running before, but stopping.  I stripped it all down and cleaned it.  I was putting it back together and oiling it today and I finally got the balance back it and this is what it is doing.  I have checked the banking manually and it looks ok so I am guessing the balance is the issue?  Any help is appreciated.
https://photos.app.goo.gl/CS44qkVSn1YwgFmt8
it is like the balance banks everything correctly and then stops
It looks like something is rubbing or scraping. The above suggestions seem likely.
For these watches, it is common for the hairspring to rub against the arms of the balance wheel or against the underside of the balance cock.
You might confirm that the wheel isn't rubbing against the pallet bridge or the center wheel.
Observe the coil from side view of the balance while running, a close up video of balance looking streight down on the bridge and side view showing the coil helps.
Coil should be flat, level with concentric circles and not foul itself.
Judging from the previous video, amplitude seems good which is a sign of hairspring free from rubbing, however you give the balance plenty of swing when you nudge it,  instead gently move the wheel see if it picks up and go at some point. (I think the balance is out of beat)
I always put just  the balance complete and bridge back( no other part)  on the mainplate for final adjustment leveling etc.  it will give you almost 330 access to the HS  around the balance wheel
What happens if you turn a gear, third or center ?
I'll second that it's a good practice to replace just the balance complete prior to assembly so you can get a good look at the hairspring.
After doing that, you can add the pallet fork and bridge to see how the fork and jewel interact.
Thanks so much for all the suggestions, troubleshooting alone is super frustrating.  I did inspect the teeth on the escape wheel under magnification for a full rotation and didn't see anything out of the ordinary
Here are some more videos of it running.  Excuse the potato quality.  I was filming from my ipad through a magnifier.  Though it seems to have decided to start running since last night.  The only thing I did different since this was to give the balance complete a lighter fluid bath
Bulova 23 issue https://imgur.com/gallery/PN5Ocr7
Edited by Wdschell
Solved I think...
I decided to give everything another look and low and behold the pallet fork stones basically fell out while I was inspecting it.
I decided to check them with just a little pressure and the moved.  Best to get a new fork or can these be glued back in?
Pallets are usually shelaced since it wont harm the base metal forks are forged out of, Marks shows how to make this tool to warm the fork on and shelac the pallet jewels, I use epoxy five on cheap pieces.
 Pallets adjustment is no easy task, nevertheless if you like to give it a try, there be plenty help and advice besides Marks lessons.
I couldn't find a link to relevent threads , some one may have more luck than I and find em.
Loose pallet jewels would do it. This is an uncommon fault, so it's worth reflecting on the cleaning procedures to see if something could have dissolved or softened the shellac. You might also check the roller jewel, which is also secured with shellac.
Replacing the jewels is not too hard, but replacing them to the proper depth is another matter. It's interesting and worth trying, but you might source a replacement pallet fork for now while you read up on it.
Dang I didn't think about the roller jewel dissolving too.  I used some generic jewelry cleaner on the fork.  I just lighter fluid on the balance complete.  I'll check it.  I am currently sourcing a 10bzac movement for the fork.  I think Dave's watch parts has one.  Waiting to hear back
It's extremely unusual that the pallet stones fallout I would definitely change your cleaning fluid. Sometimes they can be loose but usually there's visually still shellac on them
Then if you decide to put the stones back in they have to go in a specific location. The angle on each stone is slightly different so you have to put the right stone in the right slot. Then a course comes the fun of adjustment which is why we use shellac because it allows you to warm it up shellac softens the stones can be moved in and out as necessary.
Then you want to be careful when you using generic jewelry cleaners or other cleaning fluids because interesting things can happen that normally wouldn't happen if you're using proper fluids. Jewelry cleaners are not usually expecting all sorts of different metals and that can result in interesting undesirable consequences also.
7 hours ago, Wdschell said:
the impulse jewel is safe
.Roller jewel's especially on American pocket watches do tend to suffer more than the pallet stones. So in the case of a pocket watches it's always worthy to check the roller jewel to make sure it still  locked in place.
Just wanted to update this thread again.
It was indeed my fault for using the wrong cleaner to clean the pallet fork.
I got the new parts movement yesterday, installed the pallet fork and was having the same issue.  The escape wheel looked fine but since I had another I went ahead and swapped it in and voila, it is ticking away and I cant hear or see anything wrong with it now.  I inspected the old gear, but I just cant see anything wrong with it.  Even compared it to the one I swapped in.
Looks great on the time grapher now.  Thanks for all of your help in this.  Mostly, I need to bounce ideas off of someone when troubleshooting and you guys were awesome for that.  I am sure I will be around again as I think my Seiko 6139 has a loose canon pinion ?
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
