Polishing Cases
handwound
Hi guys,
I'm currently working on a project, a Seiko Pogue. I already finished the movement and wanted to restore the case now. So I ordered polishing pads for hand finishing and a polishing machine and polishing wheels for final finish. Also I got 3 polishing pastes. I wanted to try the polishing machine on a watch where it doesn't matter when I ruin it. It had some really light scratches on the caseback, so I wanted to try there. I started with the second paste (for pre-polishing) and it was working okay. I got a lot of really fine scratches, but better than before. So I proceeded with the third paste (for polishing) and it was only making scratches, no mirror finish. I tried different wheels but that didn't changed anything. What am I doing wrong? Too much pressure? The wrong pastes? Wrong polishing Wheels? Also I wondered that the paste was really hard, I expected it to be soft, is that normal?
Here you can see the tools I used:
This is the polishing paste
polierscheiben_uhren_uhrmacher_drahtbuerste_filz_uhren__schwabbel_polieren_filzkegel_beco_technic.thumb.jpg.648a7f1e9c37a7245e90b0550aab6811.jpg
the polishing wheels (from Beco)
and the polishing machine.
Edited by handwound
Hi,
I think it’s the type of polishing wheels in my opinion.  You need very fine fibre wheel.   Check ebay.     Also check retro watch guy website as he listed in order what he uses.
I hope it helps.
Regards,
Yasser.
Polishing cases is a very big subject; you can do a 6 week course at WOSTEP for many thousands of bucks and still a debutante (well you'd be better than 90% out there but needs thousands in equipment).
Without seeing exactly what you're up against it's hard to say. One big thing, when going for a fine (scratchless) polish is cleaning - clean your case ultrasonically and use different buffs for different grits. The buffs don't forget what was there before and you can't clean it off.
First of all thanks for your answers.
i know that I‘m not going to be a professional polisher after reading some posts about it, just as I‘m not a watchmaker, despite being able to perform a service and some repairs. I just don’t have the proper education and above all just not the experience.
I just want to improve the condition of the case a bit. I‘ve tried to work with less polishing paste and higher rpm now and the results were a lot better, but I still get some swirling. Also I can’t say what caused the scratches in the beginning, the case was clean, the wheels too. And the scratches were really obvious, not these very fine ones.
The polishing machine you have is a dental laboratory/jeweller's micromotor. When I polish metal with a handpiece, I prefer to start with silicone wheels.
Silicone wheels come in different diameters, shapes and grits. The coarse grits can remove deep scratches and can even round off edges if not used properly. They can give a nice brushed finish.
Medium grits give a nice satin finish. For final polishing, I use a hard felt wheel with polishing compound. But mostly I prefer to switch to a bench polisher with a larger diameter felt wheel or muslin wheel.
Yes, I chose one with handpiece because I don’t have the space for a bench polisher and I thought it would give me more precision with the smaller wheels.
I will remove the deep scratches by filing the case by hand, I will use the polisher just for the final touch. Otherwise I would be scared to lose the edges. So I don’t really need to use a silicone wheel.
Edited by handwound
It's a mix of equipment and technique.
For getting a finish free of microscratches on stainless steel, I use loose 4" cotton wheels and the Menzerna family of compounds. I step down from blue (if needed) to pink to yellow to white. In between each step, clean the case with a steamer or an ultrasonic cleaner. You can get true mirror polishing, with no swirls or scratches under a 10x loupe and raking light, this way.
An underappreciated side of this level of polishing is contamination. Different grits shouldn't be used on the same wheel, or course, but think also about your fingers, how the piece is cleaned and wiped down, and so on. A fine finish will be scratched if a piece is wiped or dried with something that has old compound residue on it.
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
    • Could you glue two pieces together for rigidity and separate after forming?
