Making a new balance staff?
Here is a broken staff from an inexpensive stopwatch.
This will be my maiden voyage into making a custom staff with my lathe.
As you can see...this does not use a jeweled roller table.
I think that this staff is one solid piece of metal, so I need to start with stock equivalent to the largest diameter of what you see here, but I am not sure.
What should I start with in terms of raw stock?  I have various kinds of rods that were passed down to me.  I also have some old clock balance wheels that I could steal the staff (if the diameter is great enough).
Thoughts?
2 hours ago, JohnR725 said:
I appear to have failing eyesight or I lack proper imagination to grasp what you're trying to say? Or maybe a picture wasn't attached.
There is a good reason for that.  I failed to post a picture.  No matter...I have already begun the task using some round steel stock I had in the watch bench.  I am about halfway done...hoping not to screw up.
There is always the tiny possibility that we can get a replacement and deny you your fun of making one.
Then it's a shame it wasn't the right kind of stopwatch? Some stopwatch is have spare parts. Their hiding so I went online and snipped out some pictures for you. This particular example actually has a note that the parts are hiding under something. Other times it's not at least I remember it's not always shown that this is where the parts are hiding.
I put lots of hours into this.  First try fail, second try stopped at this point--one pivot turned, but not the second.
The issue is the damn slot.  On the first try, I used a dremel--not a precision instrument, but it was pretty close.  Then I had a fail later in the process.
Second try, looking good, but not willing to go the dremel route again.  So, I am scratching my head and pondering a precision way to make the slot.
    • Hi! I am in the process of restoring a rado captain cook mkII. I want to remove the rotor, but I am not sure how to and need some help. As you can hopefully see on the photo there are 2 screws. The left one has two positions, the right one looks like a regular screw. I have tried turning the right one, but it does not give even after using more force than I would expect. Anyone know the function of the left screw with the two positions and how to remove the rotor? Thanks!!
