Smith's Astral help
Kieran
Hello everyone
I'm currently stripping down a smiths astral calibre 94 wrist watch and have discovered that there doesn't appear to be a click. I thought this was the case as the Watch wasn't holding any wind before stripping it down. has anybody worked on this calibre before that knows of any parts available? Please see the photographs below.
Thank you.
The click is Seiko like - see pic
I don't believe your movement is cal 94 - I think those are batch numbers. It's probably a Cal  60564 - see pic here smiths-astral-national-17
A good source for Smiths parts is John Senior at  http://www.obsoletewatchandclockparts.com/
You could try https://www.smithswatches.com/  or look for a scrap movement on ebay.
If all else fails, it's probably easy enough to make one as it's just a flat bit of spring steel..
Edited by mikepilk
Hi Mike,
Thank you for your help that is definitely the same calibre as mine. I have looked at those websites that you suggested but I haven't had any luck finding a replacement click. Is the click just an L shaped spring or is it similar to the ones found in the Smiths W10 watches (see below)? You mentioned the click is similar to those used in Seiko watches could these be used at a pinch?
All the best
Kieran
That's what they look like.  Unlikely a Seiko one would fit.
Have a look here http://www.obsoletewatchandclockparts.com/Smiths-De-Luxe-and-Astral-Parts.htm - There's an Astral click spring listed.
John is very helpful and knows about Smiths parts - I suggest you send him an email and ask if the click spring will fit.
Also see here https://www.cousinsuk.com/product/smiths-generic-parts
Edited by mikepilk
    • Heres my watch of today, a Smith 13'" RY . My missus bought me this for this Valentines day a bargain 14.99 with a reduction, the seller has occasional 20% off offers now and then so it was about 15ish with delivery. I love Smiths and i love bulleye dials, this is my first one. The watch arrived non working as stated and i knew what was inside and what would be against me, but i enjoy a challenge, we dont expect a lot if anything from pin pallet movements. A balance pivot was broken and i didnt have another staff but i did have another RY with a battered dial so i robbed the balance and tweaked it around to make it work apart from that mostly just a good clean and relubrication. Keyless works are pretty rough by design and the crown is a bugger to get in and out with the dial on, the setting lever hits the dial before it releases it, so a little mod is needed to help that along. Major problem was the pins on the lever were quite worn which make the old tg have a snow storm fit. Its a similar read for most pin pallets, these were brass as was the escape wheel. But perseverance is me, i didn't change the pins but i did spend some time dressing and polishing the worn areas which improved the trace a lot with some straightish lines 😅 and a beat error of .5 . Not sure what the lift angle should be on these and i Wasn't in the mood to work it out and who believes timegraphers anyway, but at the default 52° it runs with 260ish full 210 after 24 hours dial down , the verticals rates were pretty much all over place. So lets just put it in it's superlight aluminium case and see what happens. Been wearing it now for 3 weeks and it's consistently losing around 1.5  minutes a week winding each morning i think pretty good for an old pin pallet watch. I just love this dial, thanks wifey heres my Valentine's gift for yer sweetie x
    • I have a PDF below that will help. The problem was the PDF wasn't designed for this purpose it was designed to tell you what size watch you  have. Then it doesn't take into account movements come conceivably in different thicknesses.   watch-ligne-size-chart.pdf
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
    • Does anyone knows what size case a need for a dial diameter 20.60mm?
