WatchMeJustStarted
Hi and welcome to the forum.   Some times although the back comes off you need to remove the bezel and glass together and the the movement will lift out the front.  Not having pictures of the watch to look at. Check round the bezel for an indent or marks from a previous repairer which will indicate it is removaable.
12 hours ago, Flemmingthewatch said:
but for some weird reason the movement wont leave the case
Always nice if you give us a photograph. Otherwise we get to use our imagination of what you're describing and the answers will probably not be very helpful so we really need a picture or two or three.
    • Does anyone knows what size case a need for a dial diameter 20.60mm?
    • Sounds like the story with my Rolex. Poor (expensive) job done by an official Rolex dealer with an "in-house" watchmaker, hence I learned watchrepair and did the servicing myself. Same story as I learned with the Omega 861, again poor job by an "in-house" watchmaker by an official Omega dealer. Once your watch goes through that back-door, you have no idea what is going to happening to it 🫣   Quite nice that they sent back the parts which had been replaced !
    • yes that's definitely not right at all. I have a picture one of my friends has a Omega coaxial there was having issues to lose asking me where he should send it. As that's a specialty watch I suggested the service center. When he got it back he sent me a picture so the replace the dial as you can see the hands the mainspring barrel and I think the price was really quite decent considering all the stuff they can replace. So I do know they do change the barrels but the other person I worked at the service center when I would ask questions and unfortunately I can't remember all the answers. I think a lot of the changing a parts is at the discretion of the watchmaker. Plus I don't know enough about the chronographs and whether that would be considered a vintage watch? I take some of the vintage watches may have been sent directly to Switzerland or another service center. Obviously with a watch like the one down below they probably have a infinite supply of parts is its relatively modern vintage stuff becomes more interesting even the watch companies don't have necessarily infinite supply of parts. But no matter what the watch shouldn't disintegrated six months that's definitely an issue.
    • glad it worked out, those ESA movements are obsolete but new old stock is still out there, now that you know the make/model you could also do a cross reference to see if something more current would line up with the dial feet and hands...for future use if needed 👍
    • I wish they would have done so in this case. The whole story went like this: I sent my speedmaster to an omega service center about 10 years ago (at that point of time I haven't even started watchmaking). After the watch came back to me it had only about 6 months wristtime until january 2024 (not fair for this nice watch but the other pieces of my collection want wristtime too 🙂). So my conclusion is that the barrel was already faulty when it came back from service, can't imagine that amount of wear in 6 months wristtime. In january 2024 the performance on the wrist was quite bad, so I decided to have a look by myself. I have to admit that I didn't check the barrel close enough as I thought it must be ok, couldn't have issues after official omega service. That was a mistake, I will learn from that. Follow the golden rule: Nothing is certain except death and taxes.
