Fast log out
Homer
10 minutes ago, Homer said:
How do I stay logged in long enough to complete a message?
Your issue may be browser specific and settings within your browser.  What browser are you using?
Could be security settings in your browser...set this site as a "trusted" site.
I am sure sysadmin will chime in with more specific help...
BTW, I am permanently logged in myself--using Firefox.
2 hours ago, Homer said:
It's really irritating after one has typed a complete response only to find it disappear when you submit it!
I will try to post from an iPad and see if there is an issue.  My desktop is Windows based.
Try to install Firefox on your Macbook and see if you experience something different
Posting from my iPad. Seems to work well
Most likely a security setting in your browser. Perhaps you have cookies disabled for this site. If I was getting reports from multiple members then I would be concerned that something is wrong with our end. But I’m not and I can’t replicate your issue (I’m on MacBook Pro 16 inch with safari running latest updates and just tried on iphone - all good) so as far as I can see there’s nowt to fix.
benefit of doubt - test with a different browser. Download Chrome or Firefox.
8 hours ago, Homer said:
Using Safari on a Macbook.  Haven't had any problems on other forums.  It seems to log me out at 10 minutes whether I am typing or just reading posts.  I'm on my 4th log in .
I use either a Ipad or a MacBook Pro neither restricts my time on the site. Does it do the same on other sites
    • That's a really good idea! I have a 3d printer, I think I'll design something that I can clip on to the edge of my desk to do the same. Thanks for the idea.
    • I looked up bombè, domed in French.  It's pronunciation is bomb, does a bomb (explosive device) get It's name from bombè? I know we're going off subject but it's interesting.
    • Okay, I checked with the fine folks at the McCaw Company, and they agree it's the correct crystal, and they have one in stock, so with that sorted time to get onto assembly. Starting by getting the spring into the barrel, which was a bit harrowing. It took me several tries to get it hooked onto my worn old winder arbor, but I did find a new use for the micrometer stand I just purchased. Carefully dabbed some Kluber P125 braking grease to the left of the divots around the barrel, and a little HP1300 on the floor of the barrel before popping it in--in case you haven't seen it, this is a great illustration I found somewhere on this site. You're not the boss of me, Bulova.   2172_Bulova 11AOAC 11AOACD 11AOACB.pdf Bulova_11 AOAC, D, B(1).pdf I got the train back in and it didn't seem as free as I'd like. Looks like the driving wheel with cannon pinion has zero end shake. That could explain the low amplitutde I started with. Now if you were me, would you push on the plate jewel or the bridge jewel? I've attached some extra pictures in case anyone sees something else I'm doing wrong here.
    • I have quite a few watch brands from all over the world. For some reason this Timex electric from 1979 is capturing my attention this week. I am not a particularly fond of battery operated watches or Timex, but this one is different for some reason. Post your watch in your collection that seems to draw you in more now than before...
    • You can use bombe jewels with regular pivots if you put the convex surface facing the shoulder. You see it on (primarily older) high end pieces, particularly nearer to and including the escapement.
