how to measure a broke jewel?
gary17
hey
Just noticed the center wheel jewel was boken. I tried to remove it and what you see in pics is the outcome. I can measure the  hole size by measuring the center wheel shaft its 0.78mm but how do i now measure the jewel  itself to fit in the plate hole? Be damned hard sticking the original back together.
I have basic measuring tools but nothing for measuring broken jewels.
Any polite suggestions would be appreciated.
cheers
gary
I think it will be hard to meassure the Jewel it self, the easiest would be to meassure the diameter of the pivot which goes into the jewel hole and the diameter of the hole where the jewel goes and from that data choose a new jewel.
The pivot needs to be measured with a pivot gauge. The diameter of the jewel is tricky perhaps use drill end to find the approx size. Ps jewels purchased individually are not cheap so time spent determining the exact size is important.
22 hours ago, Nucejoe said:
Can't we go by the movement caliber and search for ref No in catalogue?
Very few watch companies list jewels sizes on their spare parts lists. Then jewels are considered generic parts I don't think I've ever seen a catalog we could look upset her jewels for instance.
If you had the Seitz Set you can use the ravers to figure out what hole size you have. Then if you have to open the hole up With one of the reamers to get the jewel for standard size you want to be really careful not to go all the way. There's a really fine line between a nice fit and having to purchase the next size jewel up in size.
If you of a smoothing broach that can be inserted and give you a clue it's not got be exact though.
8 minutes ago, thewatchdoctor said:
I see one of these in your future
I don't suppose you see the winning lottery ticket numbers? This is the big set it has everything but the smaller set that's cheaper works just fine for most people. There are few items out of the set that would be nice to have liked the jewel plate or jewel gauge. But for the most part you don't need everything here although it would be nice to have it.
I was lucky I bought most of my tools , 3 lorch watch lathes, old 1890 tissot turns, jacot turns, Touton plastic flat crystal cutter, 1000's of old VTF crystals for watches and pocket watches, ruby balance poises, spring winders, staking presses, rose cutter for pocket watch pendant rings, spare parts, 3 boxes of pocket watches, boxes of broken watches, movements etc etc from a deceased estate. The chap that passed away was a watchmaker for 50 years and the sons and daughters were clearing the house as it was to be sold. All the antique dealers there were after his clocks (200+). I saw in the corner a stacks of old cardboard boxes covered in dusty blankets. underneath was my treasure find. All the parts, tools, everything was all mixed up so it nobody was interested. I made an offer and got a call 2 days later to pay and collect as no other offers were submitted. Filled up a 1/3 of my Toyota quantum / Hiace Van. Wife said what crap have you bought now and how much. I say you'll see put your hand in that box grab a watch 1st one was a 36 rolex, next a 60 seamaster, then a small plastic case which contained a 1 carat diamond. Best buy ever for the equivalent of US $68.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
    • Aloha and thanks for catching all these small but important details, John.  I'm going to give it a shot. The good news is I have a parts movement here with a perfect complete balance.  I will place them side by side for visual reference when doing what you outlined.  It's been a while were I've had a hobby in which I joined a forum.  I forgot just how helpful everyone can be. Mahalo. Frank.
