Broken spring bar help needed!
ATagg
23 hours ago, GregC said:
I had thought about drilling it but I figured I would need a right angle attachment for the Dremel and very short drill bits to get into that small space between lugs and wasnt sure that such a gizmo existed but hey, watches to me is a new world to explore. When I came across this thread it gave me new hope that I could get that pesky piece of springbar out easily. I'll just give up on it for now as I have other cases. Thanks for the help.
I meant drilling from outside the lugs, not inside, have done so on a stainless steel case. You need a dremel stand.
I have a drill press with a mini chuck. That should do the trick but its outside in the garage and its -10C. What kind of drill bit should I use?
