Hi everyone
RichParker
Hello, I'm Richard from Sheffield.
I've been fascinated with proper watches my whole life, but until recently just from a wearing/looking at/collecting point of view.
But having successfully dabbled with and tinkered and actually repaired!! several movements whilst on furlough, I seem to appear to maybe perhaps have something of an nack??
Anyway, one way or another my interest has definitely been pricked!
But.......I have little or no actual knowledge of this field in general, other than snippets I've picked up on websites about the various types of movements and how they work. So I joined with you people to learn a bit more and.....well specifically ask about a silver 'trench' watch I came by recently that has a knackered cylinder balance. It's probably worth very little and maybe even not the genuine article, but it is a beautiful and attractive little watch and I would like to fix it and wear it.
I'll be posting more about it, but for now thank you for reading and it's good to be among fellow watch lovers.
    • So here is the new base, I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded. The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool. Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder v2.pdf Modular Movement Holder v2.pdf
    • Hi Frank, you have dived headlong into the deep end. Hairspring work has to be the scariest thing a newbie has to tackle. Your hairspring appears to be bent and just putting it back into the regulator would not allow the balance to work properly. It might start oscillating but the performance would not be good. The proper thing to do is to unstud the hairspring, remove the hairspring from the balance, reinstall the hairspring on the stud carrier, reshape the endcurve and centre the collet to the balance jewel hole. This challenge would either make you or break you. Hope that you will be able to fix your watch. Welcome to the world of watchmaking.
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
