SEIKO 6030A watch Crystal Cleaning/ Stem Removal
RNS
Good day all,
I'm a recent 30 year retiree and elected to start cleaning some of my older watches that ended up in a box wrapped in a towel.  One in particular, a gift from my grandfather, began working with a new battery but the crystal appears foggy.
I would appreciate specific instructions for removing the stem/ crown and cleaning the crystal from an 1980 Seiko with the 6030A movement.
Thank you in advance.
Regards,
Rick
Issues can easily be created if you go to remove the stem.
I just lift the palstic movement retaining ring, grab a part of the stem in long nose pliers, unscrew the crown, lift the movement out with the stem attached as you slide the stem out from inside the case.
And;   Welcome to the forum.
Good luck.
