Vertical Micrometer Usage
jdrichard
They're very useful for all kinds of things. I have a bunch of these scattered around the workshop. There are two main types- ones with flat plain tables and ones with the die plate like yours; and two main makers, both made both types, Tavannes and Prazision Falke. The Tavannes are usually 0-25mm, Falke 0-15mm.
They can be used for finding lengths along an arbor, using the die plate or a bench block if you have a plain table. Taking heights/depths off a plate or bridge. Nice for measuring inside of barrels (from barrel bottom to lid ledge for example). Pretty much any time it would be tricky to take a measurement with a regular micrometer these can help.
9 minutes ago, Klassiker said:
When does the tilt function come in handy?
It's just so you can see things more easily; with a horizontal bench mic or handheld mic it's not an issue,  but with these you find yourself bending over a lot to get at eye level with the spindle. I usually use it on my watch bench so rarely use the tilt
Big big thanks. I need to find the manual as well
1 hour ago, jdrichard said:
Ok, I bit the bullet and picked this up tonight for $200 bucks Canadian. It is in absolute mint condition as I lay here on the couch wondering what I will use this for the most:) any detailed suggestions will really be appreciated.
It is beautiful.  Some things you just have to admire.  I do.
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
