My first disassembly
Kobus
Broken movement from local supplies shop.
Unfortunately a date complication.
ID help.
1. I assume I have the minute and hour wheel correct.
2. What would the ?1 wheel be? Something to do with the date operation?
3. Have never seen this "clip" thingy at ?2.
4. What in here makes the date wheel advance?
Thanks
If I'm not mistaking, #2 is the date jumper (the thing that keeps the date ring aligned correctly).
#1 might have something attached to the bottom, that in turn pushes what I circled below, that in turn makes the date wheel advance. (sorry I don't know all the names of these parts ?)
If we go with your title of first disassembly that it's easy just take every single screw out all the parts will fall off and it will be disassembled.
If this is you learning watch repair then it would be helpful to give us something. Did ypu notice that mikepilk Has asked you two separate questions that we still Do not have an answer for? To be blunt he's asking who made this watch because it would be helpful for us to help you if we knew that. Contrary to popular belief we haven't all memorized every single watch in the universe. Or it may be possible we get technical sheets which would give us a clue what some of these parts are.
It's usually best for first disassembly to start with something like a clone of the 6497. Less things to worry about and help is available in the form of all kinds of technical and other documentation.
What I have learned (heard about before) with the first disassembly is:
Parts DO go flying around much easier than I thought, and they are much smaller than I thought. If you have a carpet you can loose a part.
For me it would be totally impossible to reassemble without plenty of pics and some notes maybe. Not difficult, impossible.
On 1/27/2021 at 9:08 AM, watchweasol said:
Hi yuo will find some data on your watch on this link      http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&AS_1791.
What is nice about the above link is we find out that the 1791 is very similar to the 1691 other than frequency.In other words one is running at 18,000 and the other 21,600. So everything else should be the same except the balance wheel and maybe some minor changes the gear train.
As I have the 1691 series parts list I'm attaching that.
This is why for first time disassembly or practicing the 6497/98 or its clones from China because are cheap are usually the preferred watch the start with. The parts are little bit bigger technical documentation Is available versus starting with older watch where all your money get is a parts list if you're really really lucky.
On the other hand not having a lead helpful information you grasp the importance of pictures. Often overlooked by all of us from time to time.
656_AS 1691, 1693.pdf
    • Thanks, Jon Sounds like a plan. Obviously I'll have the face on so do you think gripping with the holder will create any problems, but I will check in the morning to see how feasible it is but I assume it only needs to be lightly held. As for holding the movement instead of the holder won't be possible in this scenario as one hand will be puling on the stem while the other pushes the spring down. That was my initial concern is how the hell can I do this with only one pair of hands. All the other times I've had to remove the stem hasn't been a problem, apart from the force required to release the stem from the setting lever, but now I need to fit the face and hands its sent me into panic mode. If it had the screw type release things would be a lot simpler but that's life 😀
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
    • Before putting it back in the case I would fit the hands and use a pin vice on the stem to make sure the hands were in line.
