My first disassembly
Kobus
Broken movement from local supplies shop.
Unfortunately a date complication.
ID help.
1. I assume I have the minute and hour wheel correct.
2. What would the ?1 wheel be? Something to do with the date operation?
3. Have never seen this "clip" thingy at ?2.
4. What in here makes the date wheel advance?
Thanks
If I'm not mistaking, #2 is the date jumper (the thing that keeps the date ring aligned correctly).
#1 might have something attached to the bottom, that in turn pushes what I circled below, that in turn makes the date wheel advance. (sorry I don't know all the names of these parts ?)
If we go with your title of first disassembly that it's easy just take every single screw out all the parts will fall off and it will be disassembled.
If this is you learning watch repair then it would be helpful to give us something. Did ypu notice that mikepilk Has asked you two separate questions that we still Do not have an answer for? To be blunt he's asking who made this watch because it would be helpful for us to help you if we knew that. Contrary to popular belief we haven't all memorized every single watch in the universe. Or it may be possible we get technical sheets which would give us a clue what some of these parts are.
It's usually best for first disassembly to start with something like a clone of the 6497. Less things to worry about and help is available in the form of all kinds of technical and other documentation.
What I have learned (heard about before) with the first disassembly is:
Parts DO go flying around much easier than I thought, and they are much smaller than I thought. If you have a carpet you can loose a part.
For me it would be totally impossible to reassemble without plenty of pics and some notes maybe. Not difficult, impossible.
On 1/27/2021 at 9:08 AM, watchweasol said:
Hi yuo will find some data on your watch on this link      http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&AS_1791.
What is nice about the above link is we find out that the 1791 is very similar to the 1691 other than frequency.In other words one is running at 18,000 and the other 21,600. So everything else should be the same except the balance wheel and maybe some minor changes the gear train.
As I have the 1691 series parts list I'm attaching that.
This is why for first time disassembly or practicing the 6497/98 or its clones from China because are cheap are usually the preferred watch the start with. The parts are little bit bigger technical documentation Is available versus starting with older watch where all your money get is a parts list if you're really really lucky.
On the other hand not having a lead helpful information you grasp the importance of pictures. Often overlooked by all of us from time to time.
656_AS 1691, 1693.pdf
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
