Replacing crown gasket
Hi everyone,
I couldn't find anything on the forum regarding this topic, but I was wondering if anyone has any tips on replacing non Rolex crowns gaskets, as I have an old Hamilton crown with a melted gasket that's otherwise in great aesthetic condition. I removed the melted gasket by letting the crown soak in ammonia overnight and cleaning the residue with pegwood. Now I'm not sure how to go about inserting a new gasket or if it's even possible? Any help is appreciated. Thanks in advance.
18 minutes ago, watchfellow said:
Hi everyone,
If you can't locate a new replacement crown (what is so special about it?), you have three options:
- leave as-is
- lubricate the O-ring and try to squeeze it inside the crown through the gap, going around .. Could be fun (not)
- disassemble the crown (that "washer" can be pulled out), insert O-ring, and then try to secure that plate / washer (good luck)
I would go with new replacement.
Thank you for the response Poljot. Nothing really special about the crown I guess, probably just me being lazy to look for a new one (and this one looks aesthetically great). I will try option 2 before I start the search, although to be honest I have in the past tried to do just that and been unsuccessful. I've also tried option 3 in the past and never had any luck with it. I always end up mangling the washer and am not happy with the result.
Option 2 is tricky, but doable using silicone grease and a small flat screwdriver with dull tip & tweezers. You may even use some electric tape between o-ring and the blade while pushing the o-ring to prevent damaging it.
You may also search here for a new waterproof crown:
https://www.cousinsuk.com/category/waterproof-watch-crowns
I wish you luck and hope you will work something out. I am going to spend less time on this forum as I need to concentrate on some interesting and time-consuming current projects with vintage watches (jewels replacement, new balance staffs, etc). TIME for a break :-).
On 1/24/2021 at 5:36 PM, KOwatch said:
I had a similar situation, but it ended up being easier ordering a new crown than finding the correct o-ring and reassembling. Still have the old crown though, might get around to it ?
It actually wasn't so bad! The silicon grease trick that Poljot suggested worked a charm. I pressure tested the case and surprisingly it came out waterproof as well.
Thank you for the silicone grease tip, it worked really well. And the case even passed a waterproof test!
The irony of working on watches... there is just never enough time for every project.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
