modalo
gary17
hey guys
anyone know how you get to the motors on a modalo 4 watch winder.
Just got a broken one.
Want to see if i can get new motors or belts for it
The box seems to be in one piece so i presume the revolving bits the watches go in must come out some way.
if anyone knows please share.
cheers
gary
  • 2 months later...
Hi...  did you ever figure this out?   I have a Modalo, lockable 4-watch winder.   It has two big winder circles that hold two watches each.  Pretty standard I think.
I believe the belts have worn out.   I had this challenge a couple of years ago; I sent it back to Modalo; they fixed it and sent it back to me.
This time, I've had Modalo send me two new belts, but I can't figure out how to get into it.  When I look on youtube, it looks like you just twist the part of the winder that holds the watches (just the inside piece) for other winders that look like this.  But this one seems different.     Behind the two winders, it looks like there is a screw (1 behind each)...  but I can't seem to get the big winder wheel (circle) off.
Any thoughts or luck from anyone?
Here are a couple of pics.   Overall unit.
As I said, on most of these, the top wheels (watch holders) come off to reveal a couple of screws.  Typically by holding the black outside and twisting the inside.   I've tried that with as much force as I am comfortable applying.
When I try to look behind the big wheels (see the pic:  I'm pointing with a screw driver) I can see there appears to be a screw behind each one that holds the entire panel in place.  IMG_8120.jpg.7caa38b307ce26a5e4cc917f67457ba3.jpg
Regarding access through the bottom. I did have to that on another winder I had (TimeTutelary), and it was fairly easy to feel the small screw hole through the felt if you paid attention.  I have really checked this one out and didn't feel where any holes would be; pretty sure there aren't.   Where were those on yours?   I will check again.
On 11/4/2020 at 12:59 PM, gary17 said:
hey guys
cheers
gary
Hi Gary - thanks for the reply.   I've just posted a further explanation and a few pics.  Does this look like yours?  Do you have any pics of your winder and how you got in?
Hey
UNPLUG IUT FIRST.
here are a few pics the back door opens and you can the remove the slats of wood.I think the slat nearest the rear should be left to last i think it has electric parts on it. The slats have small screws holding the slats in place in the corners.
The door part (battery compartment)  i removed as it lets you peep in and trace the wires
I put this to one side as i am hectic at the moment.
But please keep me informed as i need two motors my self.
Hope pics help and please contact me if i can be any more help.
I can take more pics if needed
I need to know what motors to buy and how i get them or the belts out
good luck
gary
  • 10 months later...
Hi all
Found this thread while looking to repair my watch winder.
As described, I removed the felt on the base and found the plywood base was glued into the rebate of the boxes sides.
I found my drive belts were broken- probably as a result of ageing.
When I reassembled the box both rotors did not turn. I am suspicious the control board is faulty. Can anyone point me in the direction of where I can find a replacement or give me Modalo's contact details please ?
Thanks
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
